JDM ITR Question with PICS
Old Sep 21, 2005 | 07:09 AM
jdm_DC2R's Avatar
Default JDM ITR Question with PICS
i removed my exhaust and cat. from my car to sell...and i left the header and O2 sensor plugged in. But there was another sensor that looks like an O2 that was at the back of the cat. and wen i start the car, because this sensor is not plugged into anythin, it shows me that symbol on my gauge cluster...Any ideas about wat this is exactly? i havent seen it an a usdm ITR wen i looked at my buddies, so im wonderin wat it is on the jdm ones.
Thanks!
Old Sep 21, 2005 | 07:36 AM
Reid's Avatar
Global Moderator
Default Re: JDM ITR Question with PICS (jdm_DC2R)
Catalytic converter temp sensor.
Old Sep 21, 2005 | 07:40 AM
cryptikman's Avatar
Default Re: JDM ITR Question with PICS (Reid)
Holy huge picture man.
Old Sep 21, 2005 | 07:46 AM
Kicker773's Avatar
Default Re: JDM ITR Question with PICS (cryptikman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Catalytic converter temp sensor.</TD></TR></TABLE>
whathe said.
LUCKY CHARMS's Avatar
you can get rid of the light by earthing the wire to the body, but when i did that recently i dont think the car ran as well, so i put on a different d-cat with the sensor in place & fine now
Old Sep 21, 2005 | 07:54 AM
jdm_DC2R's Avatar
yea i noticed it ran like **** after like 7000rpms, as if it were breathless...so i will have to connect it back up, as there is no real way of bypassin this, right?
Old Sep 21, 2005 | 08:08 AM
Default Re: (jdm_DC2R)
i'm not sure of the implications of not using the sensor, personally i preffered it in, it'd be easy enough to drill/weld into a d-cat
Old Sep 21, 2005 | 08:21 AM
Marlon88's Avatar
My 2000 does not have that sensor , even when I had a 1999 JDM Toyota Glanza it didn`t have it ! And the ones that I saw that they were 96 and 97 they had that sensor after the cat !! It think it has something to do with polution control since it`s after the cat and the later cars don`t have it !
As everyone suggested , it`s a better idea to put it back in. even if you are going to remove the cat just modify the test pipe/de-cat with a bung that fit the sensor and put it back in !
Old Sep 21, 2005 | 08:53 AM
Bbasso's Avatar
sounds like you need this.
https://honda-tech.com/zerothread?id=1378081
Old Sep 21, 2005 | 10:20 AM
JDM Factor's Avatar
Sorry, Im not trying to take over the post, if you run a test pipe and make a bung for the o2 sensor, do you still get a check engine light?
Old Sep 21, 2005 | 12:55 PM
jdm_DC2R's Avatar
dont worry, you're not takin over the post, lol, and id like to know the same thing...although i dont see why the check engine light would come on...
Old Sep 21, 2005 | 01:05 PM
JDM Factor's Avatar
heh yeah I pretty much did take your post but atleast you wanted to know the same thing, I found out you can get a fix which is on another post created by Bbasso or I believe if you just make the bung you won't have the prob. I just don't feel like switchin to obd-1.
replicaITR417
Apr 25, 2010 05:20 AM
Bbasso
Nov 26, 2007 12:56 PM
integra123
Sep 20, 2006 02:26 PM
thk
Dec 5, 2003 12:55 PM
nadc2
Mar 19, 2003 04:16 AM
