1990 crx hf
your helms will tell u.i took a pry bar between the tranny and the axle and push on the bar it came right out.
tip break your axle nut lose before u jack up the car.will make life alot easier.
and remember, when you remove the first axle, tranny fluid will leak out...be ready....happy swapping or axle changing or clutch replacing or....what are you doing anyway?
basically u remove the hub nut while its on the ground....then put it up in the air and remove the lower control arm to knuckle bolt.....unbolt the fork on the bottom of the coilover assembly... then ur gonna basically pull the hub assembly away from the axle.....u can tap it with a rubber hammer if needed...once u have released it from the hub use a pry bar and a little forceand it should pop right out.....good luck
