obd2 ..searched
i searched this topic and every thread has a diff answer for some reason.. can someone identify the wires on the back of this 99-00 o2 sensor harness.. 2 black wires, which im assuming ground and can be switched without making a difference, one green, one white.. which is the heater signal and which is the power?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exare250 »</TD></TR><TR><TD CLASS="quote">actually the blacks are heater resistance wires. one goes to a 7.5 amp fuse. the other is just there to make resistence. now, green is signal, white is ground.</TD></TR></TABLE>
he's KINDA correct. this is what i persnally kno for sure.
green = ground
white = signal
both blacks = o2 heater (not sure wtf it does)
green = ground
white = signal
well heres the problem.. im wiring a o2 sensor simulator and i need to no what is what for sure so i dont take a chance in frying my ECU. does anybody know FOR SURE? not tryin to blow nothin up
1990hondaHF
Nov 24, 2004 11:21 AM
