new stage 2 clutch specialties installed. pedal is very soft!! help!
hey guys a couple of my friends all have the same set up. and there clutches are wayy stiffer than mine. what could be the problem if any? or is that normal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tarzjdm »</TD></TR><TR><TD CLASS="quote">yea i think its releasing propperly. what are the symptoms of a bad slave cyl? thanx!</TD></TR></TABLE>
If you know it is bled properly a bad slave cyl will not release the pressure plate completely. How is the condition of the master cylinder?
havnt checked the master cyl. but i bleeded the clutch a couple of times and still the same. i heard that some clutches wont be stiff. i called the guy and he said that it was a hevy duty prs plate. not an extrme one.. thanx guys.. how would i know if the master is out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports »</TD></TR><TR><TD CLASS="quote">
If you know it is bled properly a bad slave cyl will not release the pressure plate completely. How is the condition of the master cylinder?</TD></TR></TABLE>
what do you mean??
what do you mean??
yellowturbo
Feb 7, 2005 09:18 AM
AllMTRWH0R3
Aug 4, 2004 02:09 PM
