what model hatch do i have?
so I just picked up a 95 hatch, I was told it was a vx(no decals). I have looked all over the car and there is nothing that says what model it is, I know it has the d15b8 which would indicate that it is a cx but the motor could have been replaced for all I know, so does anyone know how to tell by the vin #?
The 8th digit in the Vin # sequence from left to right indicates what trim level hatchback you have. example: 2HGEH236*PH500001
4: CX
5: DX
6: VX
8: Si
4: CX
5: DX
6: VX
8: Si
mine has a 5, not a 4.
I KNOW its not a dx... CX for sure.
EDIT: ohhh, looks like you may have gotten the scale wrong based on SI guy here. prolly one up. 5=CX, 6=DX, 7=VX, and 9=SI
I KNOW its not a dx... CX for sure.EDIT: ohhh, looks like you may have gotten the scale wrong based on SI guy here. prolly one up. 5=CX, 6=DX, 7=VX, and 9=SI
Post a pic of the engine bay and I'll tell you what it is.
I owned a VX for a number of years so I'm pretty familiar with them. I wish I would have kept it, I consistently got 40+ mpg.
it has no clock no sidemoldings, its sittin on steelies(way i bought it) i wish it had the vx wheels, no power anything, does have ac, i dont get but about 30mpg but then again it has a single wire o2 sensor and the wire was draggin on the ground so it may be roughed up a bit. It has 5 as the eigth number in vin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extrmeboost »</TD></TR><TR><TD CLASS="quote">it has no clock no sidemoldings, its sittin on steelies(way i bought it) i wish it had the vx wheels, no power anything, does have ac, i dont get but about 30mpg but then again it has a single wire o2 sensor and the wire was draggin on the ground so it may be roughed up a bit. It has 5 as the eigth number in vin</TD></TR></TABLE>
Maybe I'm wrong.. Sounds like a CX. How many valves does it have? If it has 8, it's a CX.
Sounds like a CX to me. I'm almost 100% sure the VX has a 4-wire O2 sensor.
Does the cluster have a shift light?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">
Look near the turn signal, and look for a little 'up arrow', if you have one. It's a CX.
I sure the VX 92-93 have 5 wires, and the 94-95 have 4 wires. Well at least my 95 vx have 4.
Go here http://www.carfax.com/ enter your VIN and be done... Here's what it looks like for my car:
http://www.carfax.com/cfm/chec...tus=0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteSiDan »</TD></TR><TR><TD CLASS="quote">my Si has a 9, not an 8
Does your Si have ABS? Is it a 94? I have a hunch that 9 denotes the ABS equipped Si starting in 94. But i could be wrong.
</TD></TR></TABLE>Does your Si have ABS? Is it a 94? I have a hunch that 9 denotes the ABS equipped Si starting in 94. But i could be wrong.
VX's Should have:
1. Front lip
2. 13" alloy wheels
3. Tach going to 8K
4. Block should say D15Z1
5. It should have a rear diffuser on the driver's side between the rear bumper and the chassis:
6. Another thing Is the VX's have a big black EGR box mounted in the middle of the firewall. here's a pic of what i'm talking about: (NOT MY CAR)
7. Also maybe the valve cover says VTEC-E ?
mine doesn't, but others might.
8. VX should have power NOTHING: no power windows/doors/steering/seats/mirrors/locks.
9. Only comes in manual.
1. Front lip
2. 13" alloy wheels
3. Tach going to 8K
mine doesn't, but others might.8. VX should have power NOTHING: no power windows/doors/steering/seats/mirrors/locks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extrmeboost »</TD></TR><TR><TD CLASS="quote">well it definitely says d15b8</TD></TR></TABLE>
D15B8 is the CX engine.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extrmeboost »</TD></TR><TR><TD CLASS="quote">it has no clock no sidemoldings, its sittin on steelies(way i bought it) i wish it had the vx wheels, no power anything, does have ac, i dont get but about 30mpg but then again it has a single wire o2 sensor and the wire was draggin on the ground so it may be roughed up a bit. It has 5 as the eigth number in vin</TD></TR></TABLE>
As some members have already mentioned. It sounds like a CX not a VX
[QUOTE=VX]VX's Should have:
1. Front lip7. Also maybe the valve cover says VTEC-E ?
QUOTE]
The 92-93 only had HONDA on it, and the 94-95 had Vtec-E.
mine doesn't, but others might.QUOTE]
krazy562
37
May 22, 2009 12:13 PM
one slow coupe
Dec 8, 2005 04:28 PM
rtiadnoh
12
Mar 8, 2004 08:38 PM
