Would a 96-98 factory rear lip fit on a 99-00 coupe?
Old Sep 20, 2005 | 09:59 PM
jstyle_si's Avatar
Default Would a 96-98 factory rear lip fit on a 99-00 coupe?
There's this guy selling a 96-98 factory rear lip and i was wondering if anybody knew if it would fit on a 99-00 coupe. Its made for a coupe but im not sure if the 96-98 rear bumpers are the same as the 99-00 rear bumpers. If not how much shorter or longer is it?
Old Sep 20, 2005 | 10:21 PM
Stripped Honda's Avatar
99-0104
Default Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (jstyle_si)
i ordered a new bumper today and i was told that the 96-98 bumpers are different then the 99-00 not sure if the lip would work or not though
Old Sep 20, 2005 | 10:59 PM
ek4d00r's Avatar
Default Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (Stripped Honda)
itll fit with some small modifications
Old Sep 21, 2005 | 04:44 PM
jstyle_si's Avatar
Default Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (ek4d00r)
what kind of modifications would you have to do?
Old Sep 22, 2005 | 08:57 PM
ek4d00r's Avatar
take off a few of the clips i think
Old Sep 23, 2005 | 06:07 PM
jstyle_si's Avatar
so just a few of the clips and it should fit on good? a friend of mine told me that the 96-98 rear bumpers are smaller than the 99-00 is that true? if it is than that means i would have to extend the lip by cutting it right?
Old Sep 26, 2005 | 11:55 PM
brooksto's Avatar
you should pm scrapinsi, he had the 96-98 lip on a 99-00 bumper. as I recall he mentioned he had to trim the lip to make it fit.
Old Sep 27, 2005 | 10:47 AM
D50boy's Avatar
99-00 have a "lip" on the bottom edge already. 96-98s dont have that.
I have seen the old lip on the newer bumper with some mods.
Old Sep 27, 2005 | 10:49 AM
eK9aT10pSi's Avatar
Default Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (D50boy)
itll fit but it wont completely sit flush with the bumper.
Old Sep 28, 2005 | 12:03 PM
jstyle_si's Avatar
Default Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (eK9aT10pSi)
is there any cutting like that involved in making it fit?
Old Sep 28, 2005 | 04:15 PM
eK9aT10pSi's Avatar
if you have the lip, place it on your bumper and you'll see where the contour lines do not sit flush
Old Oct 3, 2005 | 04:58 PM
Ty.'s Avatar
Ty.
actually the 96-98 lip wont even come close to fitting the 99-00 rear bumper. the 96-98 bumper concaves in along the bottom whereas the 99-00 does not. you will need to add around 4-6 inches of abs plastic to makee it fit!
i have tried this as i have a 00 si and my little bro has a 96 coupe and i tried to get his to fit and i wasnt even close enough to where i would even try to modify it to fit
Old Oct 3, 2005 | 05:04 PM
huntarrr's Avatar
Default Re: Would a 96-98 factory rear lip fit on a 99-00 coupe? (EM1_R)
you can make anything fit with a little creativity. ScrapinSi made a 96-98 OEM rear lip fit on a 99-00 and it looked like it came that way from the factory.
BTW, I have a 96-98 OEM rear lip for sale
OngChien
17
Nov 9, 2008 12:24 PM
cilvia
Jan 11, 2006 09:27 PM
leadtrum
Oct 31, 2004 06:17 PM
JMD
Mar 17, 2003 04:51 PM
tnbigdawg
Mar 12, 2003 06:24 PM
