ls vtec with ls oil pump
Anyone had any problem with a ls pump with a ls/vtec set up. I am building 60 psi at wot, and 10 psi at idel, and it seems like some vtec pumps are having the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptainMorgan »</TD></TR><TR><TD CLASS="quote">Anyone had any problem with a ls pump with a ls/vtec set up. I am building 60 psi at wot, and 10 psi at idel, and it seems like some vtec pumps are having the same thing. </TD></TR></TABLE>
that oil pressure is horrible, i get 22-25 psi at idle, and 75-85 psi at wot. You need a vtec oil pump, or a late model b series oil pump. If you have an obd0-obd1 ls oil pump you need to get rid of it asap
My oil pump just took a **** on me last night. I had a stock LS one in my LS/Vtec, I was wondering the same thing-- Are the vtec ones any different than LS? Mines an OBD-2 LS block, what oil pump should I get???
RC000E
Nov 29, 2004 10:35 AM
