Tranny/pressure plate/ clutch problems
Old Sep 20, 2005 | 06:38 PM
5thGenCivicKid's Avatar
Default Tranny/pressure plate/ clutch problems
i put a clutch in for my friend today and a new tranny and he put in a 6 puck unsrung act clutch with stock fly wheel and pressure plate and tranny making alot of noise banging very hard....any imput would help should he just throw a stock disc in there?
Old Sep 20, 2005 | 06:50 PM
IMALLSLO's Avatar
Default Re: Tranny/pressure plate/ clutch problems (5thGenCivicKid)
Need more info. Is this noise at idle no load? In gear with load? In gear no load?When letting clutch out slow? Fast? Driving? Did you change the throw-out or pilot bearing? Torqued the flywheel bolts to what? Cmon......if any of us could fix your problem with the miniscule amount of info you posted,someone would be rich. More details and im sure more replies may come. **** I already think you might have left the flywheel loose. Things usually dont make a banging noise when tight.
Old Sep 20, 2005 | 06:54 PM
nocturnaldragon's Avatar
It could be a lose bolt head hitting something on the trans ect. Sounds similer to a proplem I had with mine, sounded like a jackhammer. I had left a bolt on the trans a tad lose well not lose out to far and it was just touching the pressure plate.
Old Sep 20, 2005 | 07:30 PM
boosted civic 2k6's Avatar
i hope u kno that certain 6puck clutches are meant only for racing and some just dont slip at all without lots of revving?
Old Sep 20, 2005 | 07:48 PM
Default Re: Tranny/pressure plate/ clutch problems (jxmac2o6)
ok shifting from first to second once i come off the clutch it shifts very hard and feels makes a lound banging noise only when switching gears, throw-out or pilot bearing are brand new. feels like the how tranny is gunna drop outta the car but i know all the bolts and mounts are bolted down tight
Old Sep 20, 2005 | 08:02 PM
IMALLSLO's Avatar
Sounds like you got yourself a non sprung 6 puck clutch. As long as its not a metal to metal or clanking noise,thats what it is....... . When you shift does it feel like the motor wants to jump out of the engine bay? Youll get used to it.
Modified by IMALLSLO at 9:19 PM 9/20/2005
hitvtecgetloud09
Oct 6, 2007 09:35 PM
Junkyard2000
11
Dec 20, 2005 11:51 AM
Stoich EG2
Mar 26, 2005 06:07 AM
Stoich EG2
Mar 25, 2005 10:01 PM
It's Blue
Oct 18, 2002 04:27 PM
