Need your opinion! Is this EJ1 exterior worth fixing?
Old Sep 20, 2005 | 06:17 PM
Manolo's Avatar
Default Need your opinion! Is this EJ1 exterior worth fixing?
I wanted to know if fixing up the exterior will be worth it on this shell. I don't want to invest in it if its gonna cost alot to fix the exterior. Already changed the rear and front bumper, driver side fender. Thats all the work so far done. Interior is mint though. Here is the main damage:
Bought the car with this ding.
This happend at the fourth of July. Bullet hole...long story. Little rust on door.
Guy said the car was never hit but the front light is not lining up correctly.
Old Sep 20, 2005 | 06:18 PM
hookedonvtec's Avatar
Default Re: Need your opinion! Is this EJ1 exterior worth fixing? (Manolo)
i worked at a body shop, unless u have like 2,000 sittin around, find a different one. good luck
Old Sep 20, 2005 | 06:19 PM
VRD^sam's Avatar
Default Re: Need your opinion! Is this EJ1 exterior worth fixing? (hookedonvtec)
bondo is your friend
Old Nov 4, 2005 | 11:08 PM
bokals's Avatar
Default Re: Need your opinion! Is this EJ1 exterior worth fixing? (boosted_elf)
A crappy bumper could be the problem to your headlight issue.
Old Nov 4, 2005 | 11:58 PM
::MYCORD::'s Avatar
Default Re: Need your opinion! Is this EJ1 exterior worth fixing? (core3200tm)
I really think that it is worth fixing. All the problems do seem minor. Save another Honda!
Old Nov 5, 2005 | 01:06 AM
eJone powereD's Avatar
i think it's worth fixing...if it's your project car, then why not? if not, then don't bother with it and find another...those problems arent as bad as the problems i had on my ej1 when i first got it
whatever you choose, good luck
jdmfyng
Paint and Body
11
May 12, 2011 09:32 AM
imzjustplayin
Paint and Body
Mar 15, 2009 06:08 PM
made you look
Jan 23, 2004 06:51 AM
grlstockb18c1
Dec 23, 2003 05:34 AM
integration
Jun 12, 2003 06:26 AM
