over heating ???
Old Sep 20, 2005 | 05:59 PM
CRXCIVICMIX's Avatar
Default over heating ???
My brother has a 1989 Civic Wagon.
It has a built B16A Turbo from Japan
he bout it online. We had it in the car for about
a month and now you cant run it for more then
20-30 min. before it overheats.
HELP!
Old Sep 20, 2005 | 06:03 PM
SiR Inspired ED7's Avatar
Default Re: over heating ??? (CRXCIVICMIX)
Pics
-has he changed the thermostat
- fans working?
Old Sep 20, 2005 | 06:09 PM
Default Re: over heating ??? (88 Crx Si)
He has changed the thermostat two times
fans are working
Old Sep 20, 2005 | 06:13 PM
how old is the radiator? which one he using?
Old Sep 20, 2005 | 06:18 PM
The small one from a 92-95
but it is a new one
Old Sep 20, 2005 | 07:15 PM
Mach69's Avatar
Check for leaks.
How old is the water pump?
EDIT: Bleed the coolant system.
EDIT, again: Not trying to insult you, but did you put in the thermostat the correct way?
Turn the car on without the radiator cap on. Let it idle for 30 minutes. Check both radiator hoses to see if both are hot. If the bottom one is still cold, you need to put the t-stat in the right way. If they both get hot, rev the engine and you should see the coolant flowing quickly in the radiator if you peek thru the radiator cap hole (?).
Old Sep 25, 2005 | 05:13 PM
Default Re: over heating ??? (Mach69)
the thermostat is in correct way
Old Sep 25, 2005 | 05:17 PM
g-ride-si's Avatar
does it smoke at all? Is he running an intercooler?
Old Sep 25, 2005 | 05:51 PM
maachan's Avatar
Default Re: (g-ride-si)
Check to see if there is good air flow thru the radiator. Make sure there is ram air coming in from front.
I would also check oil filter for any metal. Cut it open and see for metal. Don't use hacksaw.
Old Sep 25, 2005 | 06:09 PM
ghost_ryder35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">Check for leaks.
freshgear
Jul 19, 2009 01:48 PM
halo2k7
17
Jul 23, 2008 09:57 PM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
budget
Apr 10, 2005 12:23 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
