Slicks and wheels for K24/K20A drag EG
Old Sep 20, 2005 | 05:52 PM
CRXEE8's Avatar
Default Slicks and wheels for K24/K20A drag EG
I would like some advice on slicks and wheels for my K-series drag EG that's in progress. It will be with a K24/K20A race engine so I hoping for around 320 whp. I planned of using a 6 speed CTR tranny but might look into a 5 speed Si if it will be a better match. What kind of slicks should I look into? I thinking about M&H 26x8.5x13" but don't know if it will keep me in 4. gear with a rev limit around 8500. Anyone got some experience with K-series setups they want to share? Regarding wheels I'm thinking about 13x9 Weld Magnum with what kind of offset?
Old Sep 20, 2005 | 06:03 PM
hondaguyef's Avatar
Default Re: Slicks and wheels for K24/K20A drag EG (CRXEE8)
No personal K series/EG experience but, The 26" will be major overkill I can say that. There is an 11 sec. NA K20/EG on here running 24.5's. Try to locate him to elaborate on some better ideas. I don't know his username off hand though.
Phil
Old Sep 20, 2005 | 06:58 PM
1700anddroping's Avatar
Default Re: Slicks and wheels for K24/K20A drag EG (hondaguyef)
tell me if your interested in these.....they are weld magnum's 13x9
w/24.5x9x13 hoosier's w/4 1/8 mile passes on them.
https://honda-tech.com/zerothread?id=1282519
harv
Old Sep 20, 2005 | 07:18 PM
xtrafastcivic's Avatar
Default Re: Slicks and wheels for K24/K20A drag EG (1700anddroping)
when running slicks you want to run a smaller rim . ie if running a 8" slick run a 7" rim ..
so the sidewall is soft and has some play... you can ask M&H ...
Old Sep 21, 2005 | 03:34 AM
CRXEE8's Avatar
Default Re: Slicks and wheels for K24/K20A drag EG (XtraFastCRX)
Well I will be making a lot more Hp than Hondog and I'm sure his rev limit is higher than 8500 RPM. That's why I'm thinking about 26". What slicks size are Skunk2 and Norris running?
Modified by CRXEE8 at 5:16 AM 9/21/2005
Old Sep 21, 2005 | 01:11 PM
Hondog's Avatar
I looked at going up to a 25 or even 26" slick, even with 300whp in the near future I think I'd rather use more gears anyway. At the moment I'm running the line in 5th. on the 24.5" I managed 112mph on the JDM trans in 4th at 9000 with. if your hoping to get closer to 320whp you will be better with the USDM trans or like you say the 5spd. I think jumping on a slick size this early isn't a wise choice you'll need to try different sizes to find what works best for yo and the track you run on the most.
Old Sep 21, 2005 | 03:12 PM
CRXEE8's Avatar
Default Re: Slicks and wheels for K24/K20A drag EG (Hondog)
I have tried with a gear calc and even with 26" I don't think I can keep it in 4. gear with a euro CTR tranny. I will look into the 5 speed instead.
Old Sep 27, 2005 | 10:40 AM
Jon V's Avatar
i have heard a couple guys with teh 2.4's saying how they wished they would have gone with the 5 spd...
Or you can just buy some gears from the dealer and make your own combination...
Euro CTR is just the K20a2 right? no LSD and no short gears?
Old Sep 27, 2005 | 11:05 AM
CRXEE8's Avatar
Default Re: Slicks and wheels for K24/K20A drag EG (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">i have heard a couple guys with teh 2.4's saying how they wished they would have gone with the 5 spd...
Euro CTR is just the K20a2 right? no LSD and no short gears?</TD></TR></TABLE>
Yeah it's just a K20A2 engine and the tranny has no LSD. The Si tranny is also a lot cheaper so I think I will go with that. I can might even use my 22x8x13" M&H slicks with a 5 speed.
Old Oct 9, 2005 | 10:11 AM
cpforyou's Avatar
The Lensos VPD might be good for you. They are 13x7.5" w/ a +25 Offset.
Old Oct 9, 2005 | 10:34 AM
Suprdave's Avatar
Stock JDM Trans, 9000rpm Shift Points, 23x8x13 willl keep you in 4th.
That's with stock Horsepower tho...It really depends on your power. I woudn't go any larger than 25 tho... Thy cause alot of drag.
Old Oct 9, 2005 | 10:58 AM
cul8tr's Avatar
Default Re: Slicks and wheels for K24/K20A drag EG (Suprdave)
I have a pair of new M&H 23x8.5x15 for sale. Gimmie offers
myeg9ferio
Northern California (Sales)
May 10, 2010 10:55 AM
girliehonda
Mar 1, 2007 01:48 PM
Viorent Grip! EG
May 2, 2006 07:57 AM
jazzdacbiet
Sep 11, 2005 08:09 PM
1qWiKhAtCh
Dec 26, 2002 03:31 AM
