rear seats ?
whats up i have a problem with my rear seats i want to remove the rear seats of my car but i cant complete the hole thing i took of the bottom part but i cant take off the the top part (the back rest)
please help
please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big juan »</TD></TR><TR><TD CLASS="quote">yup does suck what car you drive ?
98 red ek on le37's
98 red ek on le37's
if your hatch is like mine and has the split fold down seats, the seats are actually just held in by some pins and a couple of clips. I believe at the outside edge (possibly the inside edge) at the pivot point, there's a little black clip shaped like a thick plastic E/C type metal retaining clip. You'd just pull it out, then slide the seat over, and pop it out. Pretty easy.....
I know from the coupes, if it's got a solid back, you need to take out the screws on the side of the brackets that hold it in, then just pop it out.... at least that's what I did.
Release the clips where the backrests pivot by pulling on them. Then just slide/wiggle the the backrests off the center T bracket between the 2 backrests on the chassis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qat727 »</TD></TR><TR><TD CLASS="quote">if your hatch is like mine and has the split fold down seats, the seats are actually just held in by some pins and a couple of clips. I believe at the outside edge (possibly the inside edge) at the pivot point, there's a little black clip shaped like a thick plastic E/C type metal retaining clip. You'd just pull it out, then slide the seat over, and pop it out. Pretty easy.....
I know from the coupes, if it's got a solid back, you need to take out the screws on the side of the brackets that hold it in, then just pop it out.... at least that's what I did. </TD></TR></TABLE>
yeah, thats right, after you remove that clip the seats should come right out. the bottoms were a bitch to get out when i first removed mine to put in inetgra seats in my hatch.
92CivicSiOEM
Jul 17, 2009 07:13 AM
broketuner-Sol_Si
Jan 5, 2006 11:41 AM
quanek4
Nov 20, 2003 07:17 AM
