Shift Linkage
you'll need the swap shift linkage. go to http://www.hasport.com there you will find what you need. the linkage you need is a great deal shorter due to the car. it is possible to cut and reweld the linkage to suit your needs but i would not advise this to a novice who doesnt have experience in this. if you do it incorrectly you could throw off the shift geometry and fry your tranny over time. the hasport linkage should run about 150.00 or so. that might seem expensive but its well worth it.
eg6sittingon57cs
Jul 19, 2007 02:41 PM
