Hardcore Relay or Fuse issue? Click on turnover... Power loss...
Old Sep 20, 2005 | 11:18 AM
Punker1234's Avatar
Default Hardcore Relay or Fuse issue? Click on turnover... Power loss...
Heya okay gonna make this as short as possibly but it's a odd problem so hang in with me everyone.
Maybe a week ago i got in my car, started it up and it made a few clicks but the car started. I shrugged it off. The clicks comes from what seems to be under the dash near fuses and I also believe maybe a click int he engine bay, not sure seeing how im inside the car.
Jump to today, car won't start. Thought it was maybe a bad battery but charged it up and still the same results. I get in the car, turn on the key and get a click. Then I get complete power loss. Nothing works, no radio no lights nothing. If i wait 5 minutes, put the key back in, fuel pump will prime and everything is good to go. I turn the key and try to start, click and no power. Now before all this maybe 2 days prior, if i tried to start it the car would make like 30 clicks all fast under the dash it seems. NO clue what this could be, as I'm an electrical noob and all my problems seem to be electrical lately any ideas? again, remember I am almost clueless
Thanks in advanced for whomever reads this novel
Old Sep 20, 2005 | 11:25 AM
Lee_Delso's Avatar
Default Re: Hardcore Relay or Fuse issue? Click on turnover... Power loss... (Punker1234)
I had almost the same situation which turned out to be my ground on my transmission, might want to check your grounds in you engine bay. If that's not it you might want to check out your ignition relay.
Old Sep 20, 2005 | 11:29 AM
Relic1's Avatar
main battery connections would be the first things I'd check.
Old Sep 20, 2005 | 12:41 PM
civic_driver's Avatar
i just threw my old battery...same symptoms.. my grounds were tight and all... battery showed 10.2V.... should be around 12.5 or so.. i've discharged this battery numerous times and it can't hold the charge any more...so i just got me a new yellow top with reverse terminals and i'm set for a while
Old Sep 20, 2005 | 01:21 PM
Punker1234's Avatar
Default Re: (civic_driver)
kk i will try a diff battery, and i checked the batery connections they seem fine. I did a tranny swpa recently but im checked the grounds and im pretty sure they are all there. Could it be a relay or something?
Old Sep 20, 2005 | 05:35 PM
Punker1234's Avatar
anyone else?
Old Sep 20, 2005 | 05:43 PM
since you did a tranny swap, make sure that you got the tranny ground tight and clean... it connects from tranny to chases on the passenger side...
i think the starter's ground is the tranny and the tranny is grounded to the chasis by that wire i was talking about... without a good tranny ground, your starter won't work
Modified by civic_driver at 7:08 PM 9/20/2005
Old Sep 20, 2005 | 07:02 PM
Punker1234's Avatar
kk i'll take a look at it tomorrow, thanks
FlewByU352
Sep 22, 2011 12:15 PM
jimmy051702
Jul 9, 2011 04:32 PM
djbrandonr
Mar 23, 2007 06:49 PM
dennis278
10
Jun 23, 2006 08:45 PM
SiRkid
Oct 20, 2005 08:56 PM
