ZC throttle body
Old Sep 20, 2005 | 11:11 AM
Slomo_civic's Avatar
Default ZC throttle body
i have a dohc zc and im wondering what size throttle body it comes with. i dont have a dial caliper to measure it. And if i wanted to buy one, which motor should i get it for?
Old Sep 20, 2005 | 12:28 PM
bump for an answer
Old Sep 20, 2005 | 01:57 PM
Kryogen's Avatar
55mm, same TB as the D16A6.
If you want bigger get a Pre-OBD B16 TB its 58mm and will bolt up to the Pre-obd intake manifold, but you must port match the intake to 58mm also.
Old Sep 20, 2005 | 04:28 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: (Kryogen)
You cannot use any B series throttle body on a D16A6 manifold.
They do not bolt up. I can bore your Tb 4mm over the stock bore. I don't think there are aftermarket TBs for the D16A6 manifold. I could be wrong.
Old Sep 20, 2005 | 04:49 PM
Kryogen's Avatar
yeah you can, ALL pre-OBD sidedraft Intake manifolds on B & D motors, the TB's bolt up the same, have the same sensors (TPS) and will work.
90-91 Integra TB's work on a A6 and ZC
90-91 siR-I B16 TB's will work on A6 and ZC.
quote- (your sig)
"Post counts don't mean a thing if you don't know what you are talking about"
Old Sep 21, 2005 | 10:32 AM
No Big Whoop
You CANNOT put a B series Throttle body on an d16A6 manifold.
Only D16Z6 or newer will accept a B series TB.
This horse is dead.
BTW, I wrote that signature specifically for people like you.
Old Sep 21, 2005 | 10:42 AM
jlicrx's Avatar
Default Re: (Maxbore)
correct - only TBs that fit DOHC ZC are D16A6 Si and D16A1 Integra - Gude has a Bullfrog TB for D16A6 - pretty nice piece
Old Sep 21, 2005 | 12:38 PM
civicflow's Avatar
Default Re: (jlicrx)
yeah, listen to maxbore and check out his site, i've only heard good things about him
Old Sep 21, 2005 | 12:56 PM
1point7db2's Avatar
Default Re: (civicflow)
Yes from my experiences b series tb will only fit d16z6 and newer im. You can put a z6 manifold on a d16a6, but it wont fit on a dohc zc.
Old Sep 21, 2005 | 03:07 PM
messeduprex's Avatar
Default Re: (DArecluse)
ok sorry if i jacked the thread what tb will fit a obd1 zc im? its a obd1 dohc zc
Old Sep 21, 2005 | 09:54 PM
LoneStarCRX's Avatar
maxbore.com
prelude182
Jan 7, 2010 12:34 PM
janz3n
Mar 29, 2007 04:39 PM
EFin' Kyle
Aug 13, 2004 06:12 PM
andertom
Aug 14, 2003 10:43 AM
