too rich at idle....and very bad idle
I have a problem with my idle, it make up and down and when I stop at the lights is die
I have check my spark plug and it's completely black
I run with a b16a2, p&p, cam ctr, intake tsuchinoko chamber, throttle 65mm, IM aebs, Exhaust manifold 4-1 mugen, exhaust 2 1/2, ecu spoon jdm p30, fuel pression regulator stock, injectors stock, fuel rail stock.
just at idle I am too rich when i run its fine
Have u hany ideas ??
the IM don't have any leak, I have check it, the iacv is well to fix and I have cleaned it, the valve of iacv functions too
The problem is not the ECU spoon because I had the same problems with a P28 chipped
I have the problem only at the idle it make up and down ans it stall, when the engine run it #1
I have make several purging of coolant and the problem is always there, I have to check after a leak with dry hair everywhere on the IM and the throttle and there is no leak anywhere, I've check every hose one by one and all is ok.
As you say, I also think that the problem must come from a defective frp
yes, but in my setup I have to estimate that it were not necessary to put an adjustable fpr, my fpr is oem and I have never to change it
but it is true that is better to have an adjustable frp but with the original spec, like that one has the gauge to be able to control the psi
forget the fpr for a second... get a fuel pressure gauge and check your fuel pressure
you can either get the fuel pressure tester "tool" or attach a gauge on top of your fuel filter... on my setup, i went with the fuel pressure gauge on top of my filter.. this way i can just look under the hood and see my fuel pressure without messing around attaching the gauge
you can get a gauge from ebay for around $20-30 shipped... if you can, find one that is liquid filled
Ok I have install a ajustable fuel pressure regulator, when I adjust the pressure around than 10 psi the idle is really really perfect it does not move but the car runs very badly
And when I adjust the pressure around + 35 psi the idle is very very bad, it die at the lights all the times, but the car runs very very well...!
How that be done??
How that be done??
boostedblue23
Sep 29, 2017 06:18 PM
Mr. Softee
Jul 3, 2002 01:52 PM
