si tranny d series
well have the new tranny in welded diff.. runs good but today for some odd reason didnt want to go into 3rd 4th 5th didnt try reverse wanted to get it home.. so im driving about 30 miles in 2nd gear and when i shut the car off.. i was trying to get it into those above gears and it did.. easily.. when i cracked the case to weld the diff. the tranny looked brand new ran great (no grinds felt like a new tranny) but now this is happening im going to pull the tranny out and see what the hell is going on.. and when i was trying to put it in them gears it felt like them gears wont even there no sound no clicking nothing any suggestions on what the hell is going on..
and i wasnt pushing in the clutch it would make a sound like something was scraping inside the tranny.. i have a act four puck and act prolite flywheel..
perhaps the diff you welded broke. or perhaps throwout bearing is going.
Does it shift when car is shut off?
I had the same problem. however I ended up doing a swap so I never did figure out the problem.
-Shane
-Shane
pulled the tranny took apart the gears everything is real good the diff (weld broke) and the i dont know what it is called but theres a rod with like a cup with springs on it the cup came off and got chewed up my tranny i have taken apart and put together i think i did a alright job runs like a champ thanks for the help
92_VX_EG
Feb 6, 2007 03:37 PM
VTgringo
15
Aug 6, 2003 11:29 PM
