Just as Good?
Old Sep 20, 2005 | 06:42 AM
Brown-tec's Avatar
Default Just as Good?
if i take off my exhaust is it just as good or better than getting a catback or w/e kind of exhaust?
98 prelude
Old Sep 20, 2005 | 06:52 AM
bubs's Avatar
Yeah, you could probably disconnect your exhaust and gain as much as a cat-back (which isn't a whole lot), but the sound will be unbearable and you will be considered a ricer by all.
Old Sep 20, 2005 | 07:14 AM
IIVIIoOkY's Avatar
Default Re: (bubs)
yeah plus i think you might be pulled over a few times because it might be considered illegal.
Old Sep 20, 2005 | 07:30 AM
The Weather Man's Avatar
WHY? wtf
Old Sep 20, 2005 | 09:35 AM
Dougs96SI's Avatar
Default Re: (TheKingPin)
No it is not as good, you will most likely fail emissions, and it will sound terrible and loud, and you will get ticketed for it all the time.
Old Sep 20, 2005 | 10:00 AM
notanotherSC61's Avatar
Default Re: (Dougs96SI)
Plus the fact that you would be throwing o2 codes and your car would smell like an oil refinery inside.
Old Sep 20, 2005 | 12:22 PM
The_Sober's Avatar
Default Re: (notanotherSC61)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">No it is not as good, you will most likely fail emissions, and it will sound terrible and loud, and you will get ticketed for it all the time.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notanotherSC61 &raquo;</TD></TR><TR><TD CLASS="quote">Plus the fact that you would be throwing o2 codes and your car would smell like an oil refinery inside.</TD></TR></TABLE>
....and don't forget that you'll be running so little back-pressure, that your mid-range and low-end will be utterly useless.
....and the metal in your header will become brittle over time because the metal is heating up and cooling too quickly
...and your car will probably run too lean because you're flowing more air, but w/out additional fuel to match
....and you'll be contributing to the ricer stereotype
Other than that, go for it!
gwegcivic
Sep 13, 2007 07:33 PM
Projectjdm4
May 25, 2007 10:57 AM
tvman
Sep 24, 2005 05:45 PM
New Dimensions
16
Apr 21, 2005 08:53 PM
