Where is the map sensor?
Old Sep 20, 2005 | 12:35 AM
slither's Avatar
Default Where is the map sensor?
Car is a 97 civic(LX)
Anyone know exsactly which is the map sensor? There are 2 plugs on the throttle body, one sits on the rear(closest to the firewall) one sits on the side, directly across from the throttle blade. I think its the one on the rear of the throttle body(closest to the firewall) but would like someone with more civic knowlege than myself to verify.
Thanks in advance!
B
Old Sep 20, 2005 | 04:53 AM
upgraded's Avatar
Default Re: Where is the map sensor? (slither)
these pics are just for refrence your throttl body might look a bit different however the map sensor should look the same.
This is the map sensor, if you loook close it shold actually say "map assy" on it.
Its the one on the left, it should have screws holding it on.
hope that helps.
Old Sep 20, 2005 | 08:30 AM
slither's Avatar
Thanks man, i figured that was it. Going to be a bitch to install the check valve though, there is a line right in the damn way. arghhhh
Thanks again man
Old Sep 20, 2005 | 10:29 AM
upgraded's Avatar
Default Re: (slither)
Old Sep 20, 2005 | 10:33 AM
Luserkid's Avatar
Dont do checkvalves, get a Missing Link.
jphil101
Apr 2, 2010 11:36 AM
SVOboy
Mar 26, 2006 11:48 AM
turbojdm521
Jun 12, 2003 11:29 AM
vti-R
Feb 7, 2003 08:57 PM
comptechgsr2000
May 8, 2002 03:53 PM
