94+ Integras: does the LS, the GS and GS-R really all get the same MPG?
Old Sep 20, 2005 | 12:09 AM
surfrider's Avatar
Default 94+ Integras: does the LS, the GS and GS-R really all get the same MPG?
from what i've read from a few websites (one being http://www.fueleconomy.gov), the integra LS and the GS-R both get 25 city 31 hwy mileage. is this really true??
Old Sep 20, 2005 | 06:36 AM
crix868's Avatar
Default Re: 94+ Integras: does the LS, the GS and GS-R really all get the same MPG? (surfrider)
its about the same on all of them jus depends on how u drive it like the manual tells u to..if u hit vtec u will burn more gas but on daily driving its jus the same except the 4dr cuz mines burns a lil more gas cuz of the weight but not much of a difference
Old Sep 20, 2005 | 09:27 AM
surfrider's Avatar
Default Re: 94+ Integras: does the LS, the GS and GS-R really all get the same MPG? (crix868)
just weird how every trim level civic gets different mileage, but all integras are the same. how much hp does the LS have?
Old Sep 20, 2005 | 09:38 AM
huepowered's Avatar
the gsr at ls should get around the same gas mileage.. the gas mileage is probably calculated when the gsr is not in vtec meaning it is using it's lower cam profile lobes versus the normal LS lobes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by surfrider &raquo;</TD></TR><TR><TD CLASS="quote">just weird how every trim level civic gets different mileage, but all integras are the same. how much hp does the LS have?</TD></TR></TABLE>
around 140 at the crank
Old Sep 20, 2005 | 09:45 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by surfrider &raquo;</TD></TR><TR><TD CLASS="quote">from what i've read from a few websites (one being http://www.fueleconomy.gov), the integra LS and the GS-R both get 25 city 31 hwy mileage. is this really true??</TD></TR></TABLE>
I would kill for 25/31 in my 00 gsr. Stock, it only got around 19 - 22 city, and maybe 28 highway, but I never burned an entire tank of gas doing highway, so I'm not sure there. Currently, I get anywhere from 17 - 20 city, but I'm sure the Azenis are to blame (more grip, more rolling resistance).
I tried driving as the owners manual suggested, shifting at 3200 rpm, but the mileage was worse. Keeping it between 3k and 4k for cruising city, and shifting around 5k seems to give me the best mileage. Maybe its time for a VAFC and tuning as a mileage booster.
Old Sep 20, 2005 | 11:08 AM
surfrider's Avatar
Default Re: 94+ Integras: does the LS, the GS and GS-R really all get the same MPG? (TunerN00b)
right now i have a 96 civic EX coupe 5spd (sohc vtec). is the LS a faster car by much?
Old Sep 20, 2005 | 11:29 AM
cm zak's Avatar
Yeah, but they probably didnt test them in bumper to bumper traffic stupid dallas highways
Old Sep 20, 2005 | 11:45 AM
happy_guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I tried driving as the owners manual suggested, shifting at 3200 rpm, but the mileage was worse. Keeping it between 3k and 4k for cruising city, and shifting around 5k seems to give me the best mileage. Maybe its time for a VAFC and tuning as a mileage booster.</TD></TR></TABLE>
or maybe you just need a major tune up
me, i drive a 95 gsr and i get 18-19 consistently, that is until i changed my thermostat cuz it was always near C, now my needle is at half tank and i got 150miles on it. so hopefully when im done ill get like 21-22 mpg
Old Sep 20, 2005 | 12:21 PM
low430's Avatar
Default Re: 94+ Integras: does the LS, the GS and GS-R really all get the same MPG? (happy_guy)
nO THE gsr gears are shorter so it uses more gas running the engine at a higher rpm.
ls tranny = gOOD mILEAGE
Old Sep 20, 2005 | 01:39 PM
surfrider's Avatar
Default Re: 94+ Integras: does the LS, the GS and GS-R really all get the same MPG? (low430)
so is the LS getting 25 cty 31 hwy or the gsr? does the LS get better mpg?
Old Sep 20, 2005 | 02:00 PM
bee18see1's Avatar
How pathetic. I get 28 on my GSR consistantly and I've had it up to 32. I could probably do even better if I wasn't a 17 year old driver if you know what I mean.
Old Sep 20, 2005 | 02:42 PM
95GSRTT
Guest
Posts: n/a
Default Re: (bee18see1)
Ya those of you getting in the teens have some major problems with your car or driving. You should never be getting that shitty of gas mileage unless heavily modded. And even with my car being turboed and untuned I get 25 mpg
Old Sep 20, 2005 | 04:09 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by happy_guy &raquo;</TD></TR><TR><TD CLASS="quote">or maybe you just need a major tune up
me, i drive a 95 gsr and i get 18-19 consistently, that is until i changed my thermostat cuz it was always near C, now my needle is at half tank and i got 150miles on it. so hopefully when im done ill get like 21-22 mpg</TD></TR></TABLE>
Car has 48k miles. Valves adjusted @ 45k mark. AEM CAI with fresh filter, otherwise stock engine. Oil changed @ 45k with Mobil1 full synth. Spark plugs all show proper combustion. Water temp warms up normally, stays at half way point once warm. Chevron 91 octane gas only. I don't see how it could need a major tune up yet, but I've certainly been wrong before. Ah well, the difference between 18 and 20 mpg isn't exactly very significant.
On the flip side, my Spitfire gets 35 city, 55 highway. But thats probably due to its absurdly light weight.
Old Sep 20, 2005 | 04:10 PM
crix868's Avatar
my LS was rated at 142hp but i dont have that motor since i blew it and now i got a jdm h22 motor which i get like only 20or less mpg
Old Sep 20, 2005 | 04:28 PM
BS 22's Avatar
I get around 25-27 mpg in my GSR, even given the way I drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bee18see1 &raquo;</TD></TR><TR><TD CLASS="quote">I could probably do even better if I wasn't a 17 year old driver if you know what I mean.</TD></TR></TABLE>
Old Sep 20, 2005 | 08:02 PM
justin.parker's Avatar
Default Re: 94+ Integras: does the LS, the GS and GS-R really all get the same MPG? (BS 22)
I just hit around 30 in my 95 LS with almost 200k miles. Was hoping for so much more :/
95-db6-719
Jan 23, 2010 07:45 AM
dorkjoey
Sep 16, 2006 10:03 PM
surfrider
Oct 19, 2005 08:11 AM
airikkCRX
Sep 1, 2005 06:49 PM
NITERYDER
Dec 14, 2004 08:57 PM
