Can a Jdm B16II obd1 wiring harness work in a Usdm obd1 car???????
Old Sep 19, 2005 | 10:07 PM
white4doorsi's Avatar
Default Can a Jdm B16II obd1 wiring harness work in a Usdm obd1 car???????
Im getting ready to buy a Jdm B16II which is obd 1. Im putting it in a 92 hatch which i also know is obd1. I wanna know can i use the jdm engine wiring harness that is coming with the car or will i have to find a usdm obd1 wiring harness for a B16II (if there is a such thing). if i can use the jdm wiring harness will it have to be modified. In case it help i already have my ecu it is a Katman chipped p28. Also is the B16II the same as the D16z6 i dont think so but i saw someone in the classifieds selling a harmess and it said it was from a Dohc? Please help i've searched to find no answers.
Modified by white4doorsi at 11:29 PM 9/19/2005
Old Sep 19, 2005 | 10:22 PM
DestructoEH's Avatar
Default Re: Can a Jdm B16II obd1 wiring harness work in a Usdm obd1 car??????? (white4doorsi)
Here's what you're looking for I believe:
https://honda-tech.com/zerothread?id=759200
Old Sep 19, 2005 | 10:23 PM
sparco562's Avatar
i used a d16z6 wiring harness from my sohc vtec engine for my gsr swap that i did to my car about three months ago and it worked out fine without any modification. have fun with your swap and you will need a integra rear tranny bracket
Old Sep 19, 2005 | 10:29 PM
thanks everyone i got my question answered
Old Sep 19, 2005 | 11:25 PM
Kendall's Avatar
I've used the JDM harness before, but I had to cut the wire loom off of it and rearrange it to fit the US engine bay. I did end up wrapping it back up with electrical tape though. It's usually less drama to use a Z6 harness though.
Prudz_lude
Dec 14, 2008 11:45 AM
24hourflipness
Jun 1, 2005 12:08 PM
24hourflipness
Apr 26, 2003 06:20 PM
24hourflipness
Apr 26, 2003 10:37 AM
