IACV question???
Old Sep 19, 2005 | 09:11 PM
drewcandraw's Avatar
Default IACV question???
How do i remove the two hoses from underneath???i know to pull the clamps with a pliers but i cant seem to remove the hoses....Also when the jumpy idle comes i hear sort of a vacuum suck in.. Does that mean it is a vacuum leak or what should i check???
Thanks in advance
Old Sep 19, 2005 | 09:21 PM
FlatlineEF9's Avatar
Default Re: IACV question??? (drewcandraw)
I just pull the clamps down with pliers and hope to god that i dont skin a knuckle when i pull the hoses off with all my might. It also helps to twist too. Hope youre hands are okay when you finish.
Old Sep 19, 2005 | 11:47 PM
Rywire's Avatar
Default Re: IACV question??? (FlatlineEF9)
Get pliers on the hose and twist back and fourth... It will break loose and come off.
Old Sep 20, 2005 | 04:23 PM
Default Re: IACV question??? (droppedcrxsi)
alrites ima try that then when the storm weather passes by
Old Sep 26, 2005 | 01:34 PM
FROSTDC2's Avatar
just use a flat head and try to peel up
Old Sep 26, 2005 | 04:11 PM
Suck my DX's Avatar
Default Re: IACV question??? (champ white coupe)
after u remove them check the condition of the hoses....it would be a good idea to change em while the iacv is already out than to redo them later
iCollectStraws
Feb 12, 2010 02:00 PM
wdissident
Mar 3, 2009 08:35 PM
1kleenef
Sep 30, 2007 10:09 AM
BlackMagikSI
10
Mar 5, 2007 06:07 AM
classified
Dec 12, 2005 04:56 PM
