PROBLEM!! IAB WIRE UP?? different explanations all over h-t! SOMEONE HELP!
Old Sep 19, 2005 | 09:09 PM
TeamYelloHead's Avatar
Default PROBLEM!! IAB WIRE UP?? different explanations all over h-t! SOMEONE HELP!
ok i just swapped in my gsr motor into my hatch and i was searching on h-t on how to wire up the secondary butterfly aka iab solenoid. so i search on ht and i read up on a bunch of different explanations that contradicts one and other. one guy says pink/blue to 12volt and black to A17 and another says pink/blue to a17 and black to ground and another says pink/blue to a17 and black to a25 and some other guy says to switch a17 and a20 and thats it. also i read about people with a black/yellow wire but my wire is just black.
so im lost and confuse, searching just makes me more lost so im just goin to ask what is the REAL correct way of wiring up the iab.
my set up is
93 civic cx
95 gsr motor with obd 2 gsr harness plugged into the cx car harness
obd 1 p72
someone please help me, im totally lost and unsure on what to do and dont feel like trial and error and *** **** up
also i am throwing NO engine codes
Old Sep 19, 2005 | 10:52 PM
Luserkid's Avatar
Default Re: PROBLEM!! IAB WIRE UP?? different explanations all over h-t! SOMEONE HELP! (TeamYelloHead)
This is what you do. You should have your 2P plug, doesnt matter the color but the plug thats originaly use is a yel/blk and pink/blue wire plug.
The part that your press on to take the plug off the sensor is up and the part with the line in it is down.
Up = Pink Blue
Down = Yel/Blk
Are you with me so far?
Ok, up goes to the ecu, Down goes to any 12volt source (i would tap it off the injectors, but thats me). On the ecu you have to tap A17.
The A26 (its not 25) they talk about is to check it. A26 is a ground wire. So you check by using your volt. meter - in A26 and + in A17. On the helms it says pink/blue is - so theyll think - = - but it doesnt. - = + . Confusing i know but easy really
Old Sep 19, 2005 | 11:00 PM
so basically, pink/blue connects to A17 and yel/black i can connect it with A25 because A25 is an ignition power source which the wire is also yellow/black. can anyone else confirm this, not sayin that ur wrong ur anything, just makes me more confident if someone else can agree on this.
Old Sep 19, 2005 | 11:10 PM
Luserkid's Avatar
Default Re: (TeamYelloHead)
Oh i see what they mean. Ok Your going to need to tap it. Dont cut and resolder because then your fucked with other things thats off it. i would just T it off the injector wires, but to each their own.
Old Sep 21, 2005 | 02:40 AM
ur info was wrong. i put pink/blue to A17 and black to a yellow/black, this caused the fuse on my ecu to blow. anyone else with an explanation on how to wire up the iab
Old Sep 21, 2005 | 08:12 AM
Luserkid's Avatar
Bring it by and ill wire it up.
Old Sep 21, 2005 | 09:47 AM
are u sure the black wire isnt to a ground, and how come i keep hearing people switching A17 with A20 or something like that
Old Sep 21, 2005 | 01:17 PM
Luserkid's Avatar
A20 is Evap. And yes its power and signal to that sensor.
Old Sep 22, 2005 | 08:58 AM
humm, then why when i put a positive power source to the black wire, it blows the fuse on the ecu.
Old Sep 22, 2005 | 09:33 AM
Luserkid's Avatar
That i dont know. My offer still stands of helping you out, if you want.
Old Sep 22, 2005 | 11:42 AM
wheres ur location?
Old Apr 3, 2006 | 05:10 PM
standinghollow's Avatar
hmm
Old Apr 3, 2006 | 05:31 PM
FaceTuned's Avatar
yellow/black is a power and the pink is the signal if that burns your fuse try grounding y/b out
Lizardslap
20
Jan 9, 2023 04:43 PM
jrsh0526
10
Jan 21, 2014 08:16 AM
BlackCivicEX
May 12, 2011 05:32 PM
ho bag
Mar 18, 2008 02:35 AM
Jakester9500
Mar 6, 2007 03:21 PM
