CTR intake cam installed on 00 si.
Old Sep 19, 2005 | 08:19 PM
klomast3r's Avatar
Default CTR intake cam installed on 00 si.
CTR intake cam installed with stock exaust cam. The head internals are stock. Do i need to up the compression at all? or leave as is.
Old Sep 19, 2005 | 08:32 PM
teamvirus's Avatar
My car breaks a lot!
Default Re: CTR intake cam installed on 00 si. (klomast3r)
compression is fine...im planning on getting ctr pistons in my si tho
Old Sep 19, 2005 | 08:56 PM
klomast3r's Avatar
Default Re: CTR intake cam installed on 00 si. (teamvirus)
Same question applies to CTR pistons.
Old Sep 19, 2005 | 09:02 PM
Dstretch33's Avatar
Nothing has to be upgraded for use of an oem cam. U can raise the compression to squeeze out some more power, and u can upgrade valve train components to increase you're red line. You do not have to do anything except drop the intake cam in, and it will be fine. What u might want to do if u have i/h/e is get a quick tune....
Old Sep 19, 2005 | 10:23 PM
underb00steg6's Avatar
dont you need springs to run ctr intake cam?? or can you run stock springs and retainer with a ctr cam?
Old Sep 19, 2005 | 10:37 PM
avex's Avatar
Default Re: CTR intake cam installed on 00 si. (underb00steg6)
if you dont rev past stock redline then you can run stock springs and retainers.
RED_90TEG
Nov 8, 2006 07:12 AM
Phatch99
Aug 10, 2004 10:31 AM
Super_Eg6
Feb 16, 2004 10:48 PM
Weslay
Mar 4, 2002 10:16 AM
