Creaking Clutch Pedal Fix
Clutch - Creaking Pedal
Bulletin No.
95-025
Issue Date
MARCH 4, 1996
Model [NEW]
1992-96
PRELUDE
1994-96
ACCORD
Applicable To
ALL
File Under
TRANS
Creaking From the Clutch Pedal
(Supersedes 95-025, dated May 8, 1995)
SYMPTOM
The clutch pedal makes a creaking noise when it is depressed.
PROBABLE CAUSE [NEW]
The coils of the clutch pedal assist spring are rubbing against each other.
CORRECTIVE ACTION
[NEW] Replace the clutch pedal assist spring with the new spring listed under PARTS INFORMATION.
1. Remove the clutch pedal assist spring.
2. Apply high temp urea grease to the ends of the new spring where they contact the bracket and to the center of the spring where it contacts the clutch pedal.
[NEW] 3. Install the new spring by putting the ends into the bushings, then depress the clutch pedal and install the center of the spring into the clutch pedal bushing.
PARTS INFORMATION [NEW]
Clutch pedal assist spring:
P/N 46980-SD4-931, H/C 4957965
REQUIRED MATERIALS
High temp urea grease:
P/N 08798-9002, H/C 3720984
WARRANTY CLAIM INFORMATION
In Warranty:
The normal warranty applies.
Out of warranty:
Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
Operation number: 2111021 [NEW]
Flat rate time: 0.2 hour
Failed part: P/N 46980-SD4-930
H/C 2348191
Defect code: 042
Contention code: B07
Template ID: 95-025A [NEW]
Modified by TheKingPin at 9:43 PM 9/19/2005
Bulletin No.
95-025
Issue Date
MARCH 4, 1996
Model [NEW]
1992-96
PRELUDE
1994-96
ACCORD
Applicable To
ALL
File Under
TRANS
SYMPTOM
CORRECTIVE ACTION
REQUIRED MATERIALS
In Warranty:
Out of warranty:
H/C 2348191
Defect code: 042
xxpaulcpxx
Feb 2, 2011 11:44 AM
