Prelude M/T Fifth Gear Grinds on Upshift
M/T - Fifth Gear Grinds During Upshift.
Bulletin No.
95-057
Issue Date
AUG 18, 1997
Model [NEW]
1994-97
ACCORD
1992-97
PRELUDE
Applicable To
ALL
File Under
TRANS
(Supersedes 95-057, dated DEC 18, 1995)
SYMPTOM
The transmission grinds when shifting into fifth gear.
PROBABLE CAUSE
The fifth gear shift fork was not manufactured properly, causing misalignment.
WARRANTY CLAIM INFORMATION
In warranty:
The normal warranty applies.
Out of warranty:
Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
Failed part: P/N 23626-PX5-326
H/C 4311536
Defect code: 042
Contention code: B07
CORRECTIVE ACTION
Replace the fifth gear shift fork, sleeve set, and mainshaft gear with the parts listed under PARTS INFORMATION.
1. Remove the transmission from the vehicle as described in section 13 of the appropriate service manual.
2. Disassemble the transmission as described in section 13 of the appropriate service manual. It is not necessary to disassemble the differential.
3. Remove any metal particles from the transmission's internal parts and the inside of the case.
4. Remove the ball bearing from the mainshaft.
5. Press the mainshaft out of the fifth gear synchro hub.
6. Install the new fifth gear on the mainshaft. Install the new sleeve set (synchro ring, hub, and sleeve) on the mainshaft.
7. Reassemble the rest of the removed parts on the mainshaft. Make sure the end bearing is installed with the lettering facing outward.
8. Replace the fifth gear shift fork.
9. Reassemble the transmission.
10. Reinstall the transmission in the vehicle.
11. Test drive the vehicle, and verify that it shifts properly.
PARTS INFORMATION
1994 - 97 Accord
Mainshaft fifth gear:
P/N 23581-PX5-A41,
H/C 3858677
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-J01,
H/C 5598909
1992-96 Prelude S
P/N 23581-PX5-U41,
H/C 3858693
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-J01,
H/C 5598909
1992-96 Prelude Si,
1992-94 Prelude 4WS
P/N 23581-P16-S40,
H/C 3940061
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-J01,
H/C 5598909
1993-96 Prelude VTEC
P/N 23581-P16-A00,
H/C 4113700
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-010,
H/C 5598917
1997 Prelude (ALL)
P/N 23581-P16-S40,
H/C 3940061
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-010,
H/C 5598917
Bulletin No.
95-057
Issue Date
AUG 18, 1997
Model [NEW]
1994-97
ACCORD
1992-97
PRELUDE
Applicable To
ALL
File Under
TRANS
SYMPTOM
PROBABLE CAUSE
In warranty:
Out of warranty:
H/C 4311536
Defect code: 042
CORRECTIVE ACTION
PARTS INFORMATION
1994 - 97 Accord
P/N 23581-PX5-A41,
H/C 3858677
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-J01,
H/C 5598909
1992-96 Prelude S
P/N 23581-PX5-U41,
H/C 3858693
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-J01,
H/C 5598909
1992-96 Prelude Si,
1992-94 Prelude 4WS
P/N 23581-P16-S40,
H/C 3940061
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-J01,
H/C 5598909
P/N 23581-P16-A00,
H/C 4113700
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-010,
H/C 5598917
1997 Prelude (ALL)
P/N 23581-P16-S40,
H/C 3940061
Sleeve set:
P/N 23626-PX5-307,
H/C 4921607
Shift fork:
P/N 24200-P16-010,
H/C 5598917
