Gs-r with LS crank
Old Sep 19, 2005 | 04:28 PM
bigmikerich20's Avatar
Default Gs-r with LS crank
ok i was talkin to my friend and he seems to think that if i put an LS crank in my Gs-R it will add torque and make it like LS/Vtec.. Is this true??
Old Sep 19, 2005 | 04:34 PM
Korch94's Avatar
Default Re: Gs-r with LS crank (bigmikerich20)
yes--- and its very commonly done
direct bolt in
Old Sep 19, 2005 | 05:15 PM
95lstegman's Avatar
Default Re: Gs-r with LS crank (Korch94)
you need more than just the crank, BTW. SEARCH is your best friend here. let's not have ANOTHER LS/VTEC debate here!! OMG
Old Sep 19, 2005 | 05:17 PM
Default Re: Gs-r with LS crank (95lstegman)
what else do i need if i may ask?
Old Sep 19, 2005 | 06:17 PM
Finger Lickin' good's Avatar
move the oil squirters.
Gsr rods wont work anylonger. However, ls rods fit perfect with b16 pistons...
ls crank
ls rods
b16 pistons
11.6 ish compression. Good streetability.
Old Sep 19, 2005 | 06:22 PM
Korch94's Avatar
Default Re: Gs-r with LS crank (Finger Lickin' good)
gsr rods can be machined to fit but imo would be pointless since this would somewhat destroke the motor
if you want you can get rid of the oil squirters but i would reccomend keeping them
and as mentioned if you are gonna go through the trouble (and are plannin on goin all motor) go ahead and put in new pistons too
Old Sep 19, 2005 | 06:35 PM
low430's Avatar
Your looking at a complete rebuild, And if your doing that why would you downgrade to the LS crank, THe GSR crank is better balanced the LS crank will have Ungodly Vibration at 8500 RPM your motor wont last
Old Sep 19, 2005 | 07:22 PM
hondaxsimike's Avatar
Default Re: Gs-r with LS crank (low430)
when u replace the crank like that it is advisable that you rebalance it before the install. and anyways when u increase the stroke of a motor you will decrease the rev limit due to the increased stress placed on the bottom end at higher rpm's. as a rule of thumb, more stroke means less rpm's, less stroke means more rpm's. this is why gsr and type r motors have a higher rev limit than an ls motor. the ls crank is 89mm so you're increasing the stroke, which should in turn give you more usable torque across the powerband. and i too would keep the oil squirters, they cut down on heat and friction.
Old Sep 19, 2005 | 07:30 PM
Default Re: Gs-r with LS crank (hondaxsimike)
the rev limit has little to do with the balance of the crank, even though balancing is very important, and definitely advisable when yer talkin about a crank swap. in fact LS cranks are the preferred stock crank to go with when you wanna step up stroke/overall displacement. in the end it all depends on what suits your need, not to say that one crank is ultimately better than the other.
Old Sep 20, 2005 | 07:01 AM
95lstegman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaxsimike &raquo;</TD></TR><TR><TD CLASS="quote">when u replace the crank like that it is advisable that you rebalance it before the install. and anyways when u increase the stroke of a motor you will decrease the rev limit due to the increased stress placed on the bottom end at higher rpm's. as a rule of thumb, more stroke means less rpm's, less stroke means more rpm's. this is why gsr and type r motors have a higher rev limit than an ls motor. the ls crank is 89mm so you're increasing the stroke, which should in turn give you more usable torque across the powerband. and i too would keep the oil squirters, they cut down on heat and friction.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaxsimike &raquo;</TD></TR><TR><TD CLASS="quote">the rev limit has little to do with the balance of the crank, even though balancing is very important, and definitely advisable when yer talkin about a crank swap. in fact LS cranks are the preferred stock crank to go with when you wanna step up stroke/overall displacement. in the end it all depends on what suits your need, not to say that one crank is ultimately better than the other.</TD></TR></TABLE>
i think what he's trying to say is stroke increase = higher piston speeds (exponential increase in normal loading of connecting rods and shear loading of crankshaft), which is why redline goes down as per Honda. raising the redline puts the crank and rods at higher loads, which increases the likelihood of failure.
using an LS crank vs. the GSR/ITR crank isn't a power producer in and of itself, but it does move the torque peak lower (this is because the piston speeds mentioned earlier have a lot to do with volumetric efficiency. when you stroke the motor, the peak VE moves to a lower RPM, which is why the torque peak moves lower, too). this feels good on the street since you don't have to rev as high to get some torque. that's really why people do it. not for power, but to move their torque peak down the powerband some. don't worry though; a nice GSR motor will do at least as well as a nice LS/VTEC.
GSR_hatch936
Apr 30, 2008 06:48 PM
swapped95
Aug 18, 2007 06:51 PM
swapped95
Aug 12, 2007 01:47 PM
hondamann_p28
Dec 20, 2003 09:25 PM
Type-ARR
Jul 21, 2003 03:33 AM
