Replaced USDM throttle body with JDM one.. now problems
Old Sep 19, 2005 | 03:57 PM
DarkBB4's Avatar
Default Replaced USDM throttle body with JDM one.. now problems
started car up and it ran like ****
threw code 7 TPS sensor
I have a vafc2 and it waas only reading 66% throttle when the pedal was on the ground (car was off)
how to fix?
Old Sep 19, 2005 | 04:15 PM
2lude4u's Avatar
Default Re: Replaced USDM throttle body with JDM one.. now problems (DarkBB4)
You'll need to adjust the TPS, using the 2 screws on the back (If it doesn't have screws, you'll need to convert the OEM bald headed screws to screws, use a hacksaw to cut a flat head slit into them). Basically with the ignition switch on you want to read .5 volts at closed throttle & 4.5 volts at w.o.t. between terminals D11(+) & D22(-). Adjust the TPS however is needed to get the voltage right.
If the voltage is right, but you are still having issues then it could be other things: idle adjustment screw, vacuum leak, IAT, etc.
Old Sep 19, 2005 | 04:27 PM
DarkBB4's Avatar
Default Re: Replaced USDM throttle body with JDM one.. now problems (2lude4u)
it has screws....how can i get this thing running tonight? or do i have to put the usdm one back on?
Old Sep 19, 2005 | 05:47 PM
DarkBB4's Avatar
i just reinstlaled the stock one, and now the throttle is like sticky.. revs high and ****!!!! help!
Old Sep 20, 2005 | 04:20 AM
Pdu-Nz's Avatar
Did you do what 2lude4u said? You have to adjust the TPS for .5 at closed throttle to 4.5 volts at WOT. You cant just slap a TPS on and call it a day.
Old Sep 20, 2005 | 04:22 AM
DarkBB4's Avatar
Default Re: (Pdu-Nz)
ya im about to put back the jdm model on, and adjust teh voltage...thanks
Old Sep 20, 2005 | 04:28 AM
The Weather Man's Avatar
Hey - i think you check the voltage at the middle wire - i haven't done it in a while- but i think the middle is the signal wire......forget which color
Or - just use your vafcII.......if you go to sensor chk - it should give you the voltage readings........with the key in the on posistion, just press on the gas and view the reading.....
mine doesn't go to 4.5, but 4.3xx - so close enuough
Old Sep 20, 2005 | 12:57 PM
DarkBB4's Avatar
Default Re: (TheKingPin)
my car is fuckd it has soo man problems wright now
elynen
Honda CR-V & Element
May 25, 2018 10:51 AM
BIGef
Jul 22, 2013 10:01 AM
TonyRomo
Dec 27, 2008 03:13 PM
Rayog21
Aug 6, 2006 08:56 PM
deacs
Oct 7, 2002 10:30 AM
