clutch/flywheel HELPPPP
Old Feb 28, 2002 | 04:33 PM
iwhichisme's Avatar
Default clutch/flywheel HELPPPP
ok i have a y1 with a cm flywheel, and act clutch. when the car is idling thers a knocking sound, when i push in the clutch it quiets, but the noise is still slightly there. when im driving the knocking the continues, and there is a little vibration. when i down shift it seems like its having a hard time adjusting. Last the clutch isnt grabbing as hard as it should, it shifts but doesnt grad like it should. is my TO bearing, input shaft, or is there oil somewhere in the mix, what da deal ???
Old Feb 28, 2002 | 04:42 PM
rainforest's Avatar
Default Re: clutch/flywheel HELPPPP (iwhichisme)
prolly the throw out bearing or a loose input shaft. but most likely the tob
CubbyChowder
16
May 4, 2010 02:17 PM
freshtyper
Jul 8, 2005 03:59 PM
d_mina
Feb 3, 2005 12:06 PM
turbo Si
May 5, 2002 08:44 PM
