bad gas milage ??
Old Sep 19, 2005 | 11:08 AM
hedtrip's Avatar
Default bad gas milage ??
ok .. my crx has been getting really realy bad gas miliage ,,,& im not sure why what are some things 2 check or fix ? ...my setup is : 88 Crx HF witha a 99 D16y8 ,,with a 95 Cx Intake MaNi & TB ...it's still obd0 so no V-tech . Si tranny ,,, Si ecu ..Y8 map sensore ,,,, i cant afford 2 drive the damn thing .with gas prices so high ...lol
Old Sep 19, 2005 | 11:42 PM
hedtrip's Avatar
Default Re: bad gas milage ?? (hedtrip)
BUMP!!
Old Sep 20, 2005 | 01:40 AM
crxnj's Avatar
By bad mpg ,what do you mean?..25mpg,30mpg?? I have a b16a with some headwork and get around 35-40mpg with a b16 tranny/w ls 5th gearset
Check tires pressure..
air filter
spark plugs
oil change/oil filter
Lucas fuel injector cleaner
Check o2 sensor
Old Sep 20, 2005 | 07:13 AM
SiMateoAko's Avatar
Default Re: bad gas milage ?? (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
air filter
spark plugs
Check o2 sensor</TD></TR></TABLE>
I'd also check the distributor to make sure it's clean in there.
Old Sep 20, 2005 | 07:15 AM
deftones0817's Avatar
Default Re: bad gas milage ?? (SiMateoAko)
convert over to obd2 and run the stock ecu and your gas mileage will improve. you can't expect and obd0 computer to run an obd2 engine 100% correct.
Old Sep 20, 2005 | 08:12 AM
hedtrip's Avatar
Default Re: bad gas milage ?? (QuickwhipsCRX)
no it's more ,,like 8 to 10 mile's to tha gallon .. i can live with the 24 to 30 ..lol
..but yea imma change my 02 sensor & see if thats it ... thanx
Old Sep 20, 2005 | 09:55 AM
g-ride-si's Avatar
i dont think a bad o2 is gonna help that much when mine went bad on my old a6 i went from 35-38mpg to about 30-32mpg.
Old Sep 20, 2005 | 12:10 PM
SiMateoAko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuickwhipsCRX &raquo;</TD></TR><TR><TD CLASS="quote">convert over to obd2 and run the stock ecu and your gas mileage will improve. you can't expect and obd0 computer to run an obd2 engine 100% correct.</TD></TR></TABLE>
This is it exactly. your o2 sensor MIGHT have something to do with it, but the fact that you're running a obd0 ECU on an obd2 engine will explain around 90% of your mileage problems.
Your engine wasn't built for the ECU you're running. Swap the ECU, get the conversion harness (or get a whole new harness) and wire up vtec properly. I'd say you'd get 25-35 mpg easy.
Old Sep 20, 2005 | 09:17 PM
hedtrip's Avatar
it being a obd2 moter has nothing 2 do with it .. i had the same moter & **** in my 88 Hatchback & it ran just fine
Old Sep 20, 2005 | 09:19 PM
EL Vap133's Avatar
Any symptoms?
Old Sep 20, 2005 | 10:36 PM
hedtrip's Avatar
Default Re: bad gas milage ?? (EL Vap133)
the plugs are black.. but they aren't that bad ,,so it's running pretty rich ... the oil looks good, i changed the o2 .. no change .. how about injectores ? .. would a fucked up injector cause this ? mybe it's stuck open ... ?? & how about my map sensor ? would it cause this ?
im throwin 3 & 5 ..witch is the map sensor ..
Old Sep 21, 2005 | 04:08 AM
well man here you go so your saying an obd0 ecu that isnt chipped is goign to run a obd2 engine just fine. That is bull. It may run but it will never run totally correct unchipped and untuned. If its runnign rich in a nother car like rediculoius richi it might be that you wired something wrong. Bump for you non the less.
Old Sep 21, 2005 | 07:49 AM
SiMateoAko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuickwhipsCRX &raquo;</TD></TR><TR><TD CLASS="quote">well man here you go so your saying an obd0 ecu that isnt chipped is goign to run a obd2 engine just fine. That is bull. It may run but it will never run totally correct unchipped and untuned. If its runnign rich in a nother car like rediculoius richi it might be that you wired something wrong. Bump for you non the less.</TD></TR></TABLE>
And when you are throwing codes, it's the first thing to check and replace.
but if I were you, I'd shell out $50 for an obd2 ecu.
SIC-CIVIC
12
Oct 25, 2007 08:43 PM
joaodossantos
Jun 9, 2007 08:18 PM
crxisok
Jul 5, 2006 07:10 PM
vizion22
Sep 24, 2004 06:37 AM
SpeedMonkeyRacing
Jul 10, 2003 11:51 PM
