crx obd0 to obd1 conversion help!!
hey, guys i just wanted to know what parts i needed for a obd0 to obd1 conversion. i have a crx si w/ d16z6 motor, but everything else is from the si, ecu, dizzy, etc. i've been lookin around but seems like everyone says something different. some say all you need is the dizzy and ecu and some say you need the ecu, dizzy, and jumper harness. stuff like that. so if any of you guys know exactly what i would need for the conversion please let me know. thanks
check out rywire.com or boomslang.us
what u need is:
obd0-obd1 jumper harness
Dizzy clip over ( if you dont wanna repin your engine harness)
obd1 fuel injectors and injector pigtails
4 wire o2 sensor
obd1 ecu ( p28 for your d16z6 )
what u need is:
4 wire o2 sensor
hey guys i know this sounds stupid but if i were to unhook the crx si ecu and connect a jumper harness and then connect a p28 ecu to the jumper harness would that do anything or would just end up killing my motor?? i have a d16z6 in a crx si
It probably wouldnt run.
You need to wire in the obd1 distributor, since some of the pinouts are different.
You could probably run it without the 4 wire o2 sensor, but you will most likely get a check engine light, and it will run very poorly.
You can keep the obd0 injectors and resistor box, and the car will run well, but it might run a little better with the obd1 injectors.
92hatchattack
Aug 23, 2004 11:15 PM
CRX_GUY_123
22
Jun 8, 2004 10:57 AM
