----> advice - motor is acting all F*cked up- ASAP!
Old Sep 19, 2005 | 08:43 AM
Viorent Grip! EG's Avatar
Default ----> advice - motor is acting all F*cked up- ASAP!
sup guys...some help, advice, opinions wanted for this matter....the basic run down is..my car is acting all jacked...why? no damn clue
-the car was at my friends shop. While the car was stationary, the motor was revved up to about 4k on a conservative throttle %. suddenly, the motor freaks out!..sounds like it suddenly ran on 3 cylinders, cant hold idle, lumpy, choking and then dies out. tried starting her again...same story...chokes out then dies. the motor has been broken in properly after the build, tuned and driven without any headache for the entire '05 year to date.
here is what we have trouble shot so far-
checked/ swapped plugs, wires, distributor, ecu's, did compression test-225psi all the way across. did a leakdown test-all 4 cyl 100% perfect, check valve clearance, swapped MAP sensors, checked fuses, no vaccum leaks, proper oil and water levels, checked injector power signal, cleaned and inspected injectors, swapped fuel regulators, all four's get spark, no timing belt or sprocket splipage
symptoms- we take the plugs out...clean them, put them back in, fire it up a couple times...pul the plugs back out...coated completely BLACK...
i cant understand whats going on...at least so far the motor seems healthy...
-car 93 eg si
-built jdm b18c gsr obd1
-11.5 comp @ 81.5mm bore
-hondata s200 p28
Old Sep 19, 2005 | 08:47 AM
mmuller's Avatar
Mad Scientist
Default Re: ----> advice - motor is acting all F*cked up- ASAP! (Viorent Grip! EG)
have you tried swapping dizzy's?
Old Sep 19, 2005 | 10:41 AM
Default Re: ----> advice - motor is acting all F*cked up- ASAP! (mmuller)
swapped distributors....and still nothing
Old Sep 19, 2005 | 01:09 PM
Old Sep 19, 2005 | 01:10 PM
dsowers19's Avatar
Did you check the fuel pressure going into the fuel filter? Might be a fuel pump
problem as well.
Old Sep 19, 2005 | 01:21 PM
Default Re: ----> advice - motor is acting all F*cked up- ASAP! (dsowers19)
fuel pressure gauge reads proplery...tuned at 42psi
Old Sep 19, 2005 | 04:46 PM
anyone have any experience with this?
Old Sep 19, 2005 | 08:28 PM
sicsixone's Avatar
did you posibly use a differant type of injector. dont know what type of car that you have.but there is peak and hold injectors and saturated type.
Old Sep 19, 2005 | 09:59 PM
HondaTom's Avatar
Have you checked the O2 sensors?
Old Sep 19, 2005 | 10:02 PM
Default Re: ----> advice - motor is acting all F*cked up- ASAP! (HondaTom)
02 sensor has recnetly been changed out with one that was from my friends car..
the injectors are saturated..and have not been swapped out but cleaned and inspected...
bumpers
Old Sep 20, 2005 | 05:36 AM
f1 vtec's Avatar
Sounds a bit like the problem im having but my car fires up when i adjust the throttle cable when the car warms up it revs at 3000rpm. doesnt fire on cold sounds like your car dying off etc black plugs etc etc
dunno what it could be tho? im gonna get my timing checked this weekend maybe something there
Old Sep 20, 2005 | 08:23 AM
Default Re: ----> advice - motor is acting all F*cked up- ASAP! (f1 vtec)
thanks for the advice and opinioins on this matter...i really want to get the car up and running asap.
one of the main concerns i have is...the car was tuned less than 3 months ago from a very reputable honda tuner in so cal. no further tweeks or additional tuning was made to the motor after the initial tuning session. odd for me to see how timing can just get thrown off like that instantaniously.......boggles the mind...
Old Sep 20, 2005 | 10:43 AM
IN VTEC's Avatar
Check MAP sensor input voltage to the ECU.
It also might be a wiring issue. If it has a CEL, then look into it.
Old Sep 20, 2005 | 10:55 AM
Default Re: ----> advice - motor is acting all F*cked up- ASAP! (IN VTEC)
swapped the map sensor...no changes....
however ecu and sensor voltage is soemthing i'll do...
anyone have a chart or graph or proper sensor voltage on b series?
Old Sep 20, 2005 | 05:41 PM
anymore thoughts?
Old Sep 21, 2005 | 01:12 PM
bump
Viorent Grip! EG
Sep 19, 2005 06:19 PM
yoshio006
Aug 19, 2003 07:36 AM
People_Mover
Jan 29, 2002 09:46 AM
People_Mover
Jan 27, 2002 07:25 PM
