ls hatch times
Old Sep 19, 2005 | 07:25 AM
reallycooleg's Avatar
Default ls hatch times
been goin to to the track for a while
ran a 15.1 @ 90mph...with a 2.2 60'..
my car is a eg dx hatch cut better 60's but ran slower times the 2.2 60' was the quicker run..
set up was stock motor. ls trans i/h/e, msd ignition and and 20/8/14 slicks at 22psi...comments??
Old Sep 19, 2005 | 07:29 AM
tthame1's Avatar
Default Re: ls hatch times (reallycooleg)
22psi is way too much for slicks, put them down to about 8-10psi and try again.
Old Sep 19, 2005 | 07:51 AM
darkdementshun's Avatar
Hmmm, i have never really seen a LS hatch that couldn't break into the 14's on street tires unless something was wrong. Friend was running 14.7's on up to 14.9's consistently in his hatch. With the slicks, make sure the pressure is right. Like tthame1 said, 22psi is waay too much. When you do your burnout the pressure will be raised anyways, so get to about 12psi and start going down from there. Also make sure you are not bogging with the slicks. Rev, preload, launch, and drive. Simple as that. lol, simple.....
Old Sep 19, 2005 | 09:11 AM
99lspwr's Avatar
Default Re: (darkdementshun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkdementshun &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm, i have never really seen a LS hatch that couldn't break into the 14's on street tires unless something was wrong. Friend was running 14.7's on up to 14.9's consistently in his hatch. With the slicks, make sure the pressure is right. Like tthame1 said, 22psi is waay too much. When you do your burnout the pressure will be raised anyways, so get to about 12psi and start going down from there. Also make sure you are not bogging with the slicks. Rev, preload, launch, and drive. Simple as that. lol, simple.....</TD></TR></TABLE>
Check out my recent post in drag racing.....Eg w/ full ls swap, e-bay intake, apexi n1 catback, faulken zeik tires, 14.5@ 94 mph, w/ 2.0 60ft...
Old Sep 19, 2005 | 12:06 PM
Default Re: (99lspwr)
i dont think any thing s really wrong with my setup it dyno'ed at 137 hp and 119 torque its always ran times like this...it just not a 14 sec car...i weigh a bit so that might be an issue..
and whats preload mean??
Old Sep 19, 2005 | 12:25 PM
Default Re: (reallycooleg)
The point is that you have room to improve. 2.2 60's on slicks are not good. You should be aiming at 1.8-2.0 60' times. My friend is around 6'4" and 240lbs, and he still managed to get 14.7 @ 93mph on street tires. The slicks might be bogging you down too much. Perhaps run on street tires and try some 20" slicks. I know some other people on here have had good luck with 20" slicks. I personally only have used 22", but it might be too much traction for your car. Just keep trying different things.
Preloading is discussed in quite a few other threads. Basically stage up and use the e-brake to hold you in position while you rev to the roof and disengauge (sp?) your clutch to the point that you almost start moving forward. This "preloads" the drivetrain thus reducing stress when you launch. People on here have run well into the 10's on 25" slicks with stock axles using this method. Play around with different launching techniques and find one that works well for you
Sorry, saw 22psi and thought it was size of slicks. 20" should be fine.
nevin's Avatar
sounds normal to me
I ran 15.1 in a crx with stock ls motor but with stock i/h/e on the same 20x8x14 slicks
Old Sep 19, 2005 | 06:39 PM
Default Re: (nevin)
ill try to preload but at what rpm should i launch at??
Old Sep 19, 2005 | 06:54 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
my friend ran 14.8 in his hatch with a stock LS on azenis......
Old Sep 20, 2005 | 03:01 AM
Calvinator's Avatar
Default Re: ls hatch times (Snoflake)
my friend ran a 14.4 in an LS with jg 301s, ls tranny and stock clutch. Gutted vx with a 2.4 60ft on shitty street tires.
I suggest lowering your tire pressure and launch at redline.
.Hatches.
Oct 3, 2008 10:36 AM
shoebox
Jun 9, 2005 06:35 AM
reallycooleg
May 19, 2005 03:59 PM
reallycooleg
Oct 9, 2004 12:14 PM
TinyLSHatch
Oct 8, 2004 05:59 AM
