my heat dont work in my 89 crx si. what do u think is wrong??
Old Sep 19, 2005 | 04:23 AM
h22_crx's Avatar
Default my heat dont work in my 89 crx si. what do u think is wrong??
Old Sep 19, 2005 | 05:35 AM
coot_er's Avatar
Default Re: my heat dont work in my 89 crx si. what do u think is wrong?? (h22_crx)
does your fan not blow? or does it blow, just not hot air?
Old Sep 19, 2005 | 05:56 AM
goforbroke's Avatar
MEAT PATTY
Default Re: my heat dont work in my 89 crx si. what do u think is wrong?? (coot_er)
Like cooter said^is your fan coming on? Did you check your fuse yet?
Old Sep 19, 2005 | 07:43 AM
h22_crx's Avatar
its blows air no hot air
Old Sep 19, 2005 | 07:59 AM
speedd2286's Avatar
samethign happened to me after i swapped in my zc...blows air but not hot air..
Old Sep 19, 2005 | 08:29 AM
h22_crx's Avatar
Default Re: my heat dont work in my 89 crx si. what do u think is wrong?? (speedd2286)
i have the same problem with my si motor
Old Sep 19, 2005 | 08:38 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Make sure the valve is open..[Outlined in center of picture]
Push the valve toward the firewall to open it..
Old Sep 19, 2005 | 08:56 AM
speedd2286's Avatar
Default Re: my heat dont work in my 89 crx si. what do u think is wrong?? (88DXCRX)
i thought it had something to do with that..,just had to make sure...thanks
Old Sep 19, 2005 | 10:47 AM
h22_crx's Avatar
if it not that what would it be
Old Sep 19, 2005 | 01:04 PM
Tyson's Avatar
then its the air mixture flap not being connected.
the temperature **** changes TWO things, the heater hose valve, and the air mixture flap. the cables leading to the air mixture flap often get disconnected or malfunctioning.
the lever for this is located at the bottom of the heater core. you can get a look at it by crawling in the passenger footwell and look up under the heater core. look for the white plastic thing. reach up and twist the temp **** and you get an idea of how it works.
drm109
Aug 10, 2008 04:30 PM
circapunk
Nov 19, 2007 06:20 AM
nihad
Feb 11, 2007 02:08 PM
SLPN H
Dec 11, 2006 04:29 AM
barry11j
Mar 4, 2005 11:31 AM
