Tach revs at idle...
Old Sep 19, 2005 | 03:41 AM
BigRonDawg's Avatar
Default Tach revs at idle...
I searched to no avail...
My hatch recently started reving at idle on it's own. It's just a constant rev up to 2 grand then back to idle over and over again. It doesn't do it when i first start the car up, it seems like it has to get warmed up. Anyone experience this?
Thanks guys.
Old Sep 19, 2005 | 04:27 AM
Dirtfall's Avatar
Default Re: Tach revs at idle... (BigRonDawg)
Wierd it sounds like im having the same problem tonight also. Might want to keep an eye on my thread also. Hopefully we get this fixed
https://honda-tech.com/zerothread?id=1375956
Old Sep 19, 2005 | 05:52 AM
jdm123's Avatar
Default Re: Tach revs at idle... (Dirtfall)
sounds like it could be a vaccum leak. happened with a friends of mines car after he swapped a gsr in.
Old Sep 19, 2005 | 07:19 AM
gapergurlie_18's Avatar
yep what jdm123 said i think its a vaccum leak
Old Sep 19, 2005 | 07:35 AM
Phillyhatch's Avatar
could be your IACV (idle air control valve), its a common problem w/ hondas. screen may be clogged. try cleaning the carbon deposits on the IACV screen. just remove it from the back of the manifiold (2 bolts), disconnect vacuum lines, clean it, put back on and see if it makes a difference
Old Sep 21, 2005 | 10:22 AM
try these 2 links that might help if your still having problems.
http://www.findarticles.com/p/...83803
http://www.findarticles.com/p/...84454
Old Sep 21, 2005 | 11:04 AM
JDM-EJ1's Avatar
Default Re: Tach revs at idle... (jdm123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like it could be a vaccum leak. happened with a friends of mines car after he swapped a gsr in.</TD></TR></TABLE>
Could be this. However, when it happened on mine, I adjusted my idle adjustment screw on the intake manifold and it fixed it.
Old Sep 21, 2005 | 11:11 AM
BigRonDawg's Avatar
Default Re: Tach revs at idle... (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Could be this. However, when it happened on mine, I adjusted my idle adjustment screw on the intake manifold and it fixed it.</TD></TR></TABLE>
this is what i did yesterday and it has been fine since...
i hope it was the problem, i'll keep my eye on it.
Old Sep 21, 2005 | 11:16 AM
riceburnerryan's Avatar
if its not those .. just listen to the guy abotu the Idle Air Control Valve... my friends was having that problem and he replaced that.... also a vacuum leak is possible too... just go through and check
Old Oct 1, 2005 | 04:28 PM
Hebrew-Hammer's Avatar
Default Re: (riceburnerryan)
i recently installed a TBS on my intake and it started to rev at idle, i cleaned out the iacv but it still continues to rev.
Old Oct 2, 2005 | 01:23 AM
jdmpremonition's Avatar
a friend of mine had that same problem and he found out it was his o2 sensor. you might want to try that if nothing else works...
Old Oct 2, 2005 | 03:30 AM
vc's Avatar
vc
Default Re: (jdmpremonition)
I have the same problem, but it goes away after I'm warmed up.... and it only happens when I hit some gas before its warmed up.. 1.2k-2k rpm..... 1.2k-2k rpm..... up and down
Old Oct 2, 2005 | 06:30 AM
spoonhatchback2001's Avatar
it could be all those problems but deepding if your engine is moded with turbo or some sick na setup your car might be running to rich to the ECU at idle revs your car to compensate for the extra fule at idle when it is warmed up
Old Oct 3, 2005 | 01:23 PM
mine dosnt start reving at idle until i mess with the throttle then it starts being gay.
Old Oct 3, 2005 | 02:38 PM
vc's Avatar
vc
Default Re: (Hebrew-Hammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hebrew-Hammer &raquo;</TD></TR><TR><TD CLASS="quote">mine dosnt start reving at idle until i mess with the throttle then it starts being gay.</TD></TR></TABLE>
exactly...
Old Oct 3, 2005 | 06:38 PM
Default Re: (vc)
im gonna try getting a new iacv and trying that out.
Old Oct 9, 2005 | 03:27 PM
well i took the TB off my car today determind to fix the reving problem, turns out that apiece of my old TB gasket found it was into the orphis to the iacv so i shot it dosn with some TB cleaner and swabbed it with a cotton swab now it all better. and i found that my TB was insanly dirty and i ahd just cleaned it out not even 100 miled ago. So i inspected and found that my airfilter had a rip in the inner linning leaving a hole for all sorts of things to enter my intake, since im broke i just mendid it with some fabric softener sheets till i get paid.
EGIan
10
Feb 11, 2009 07:52 PM
90AcuraIntegra04
Dec 11, 2005 05:26 PM
jam05pr
Oct 29, 2005 01:15 PM
225DC2GSR
Jun 22, 2005 10:42 AM
