Is this the throwout bearing or input shaft...?
Old Sep 18, 2005 | 10:21 PM
crxnj's Avatar
Default Is this the throwout bearing or input shaft...?
Loud grinding noise coming from the tranny..Almost sounds like a airplane or some **** ..Goes away when the clutch is pushed down..
I searched and some say its the input shaft bearing..others say its the throwout bearing..I need a certain answer..
Also I changed the spark plugs today and there's a shitload of oil in 3 of the cylinders..Anyone know about this??..(B16a motor)
Old Sep 19, 2005 | 10:47 AM
CRXSI_09's Avatar
Default Re: Is this the throwout bearing or input shaft...? (Mr.speaker)
I'd say bad piston rings caused the oil to get into your firing chambers.
Input shaft or clutch release bearing, both are pretty easy to change out. Clutch release being way easier. Just spin the clutch release when you take off the tranny. If it clicks, it's bad. If not, you have to take off the casing and replace the input shaft bearing. Not hard, just time consuming.
I had to replace my input shaft bearing about two weeks ago. I just changed all of the bearings, cleaned each gear with a q-tip and oil, and hot tanked the casings. Came out really nice. Now my second gear grind is gone.
Just take your time and label your parts.
Old Sep 19, 2005 | 10:54 AM
user 98292739's Avatar
are you burning any oil? maybe valve seals are bad too. and it sounds like your input shaft bearing is messed up if the sound goes away when clutch is pressed in.
Old Sep 19, 2005 | 12:35 PM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Loud grinding noise coming from the tranny..Almost sounds like a airplane or some **** ..Goes away when the clutch is pushed down..</TD></TR></TABLE>
If the noise goes away when you push the clutch [this is when your transmission stops turning and your throw out bearing starts turning], then it is a bearing that is inside the transmission. You need to change this ASAP before the bearing comes apart. This happened to me and destroyed the clutch housing.
Old Sep 19, 2005 | 01:02 PM
crxnj's Avatar
Default Re: Is this the throwout bearing or input shaft...? (DaX)
Damn,,that sucks..I guess its My own fault for changing the clutch and not changing any of the bearings while everything was apart..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rexified &raquo;</TD></TR><TR><TD CLASS="quote">are you burning any oil? maybe valve seals are bad too. and it sounds like your input shaft bearing is messed up if the sound goes away when clutch is pressed in.</TD></TR></TABLE>
Yeah about 1qt a month..And I get alot of blue smoke over 4,000 revs..
Old Sep 24, 2005 | 04:27 PM
sounds like your rings are bad
Old Oct 2, 2005 | 02:01 AM
mikey-ej7's Avatar
guys, how much is a input shaft bearing, and where should I buy one? Any brand the best?
Old Oct 2, 2005 | 05:50 AM
DaX's Avatar
DaX
Loved
Community Favorite
Local dealership or http://www.hondaautomotiveparts.com
Should be less than $20
Old Oct 6, 2005 | 11:18 AM
supapoopa's Avatar
Default Re: (DaX)
I have this same problem and am going to attempt to do it take it apart with a friend. Once i take apart the transmission housing what will i need to replace other then the input shaft bearings? Are there any parts that are not replaceable when i remove and open that i should have in hand to replace when rebuilding?
Where can i find the best deal on a Helm's manual?
Old Oct 6, 2005 | 11:34 AM
type Gendy's Avatar
Default Re: (supapoopa)
Where to get a bearing for a y1 transmission of a b16a ? Would this be from a 90-91 integra ?
Old Oct 9, 2005 | 06:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supapoopa &raquo;</TD></TR><TR><TD CLASS="quote">I have this same problem and am going to attempt to do it take it apart with a friend. Once i take apart the transmission housing what will i need to replace other then the input shaft bearings? Are there any parts that are not replaceable when i remove and open that i should have in hand to replace when rebuilding?
Where can i find the best deal on a Helm's manual?</TD></TR></TABLE>
I like to replace all the rubber on the tranny and the pickup magnet while I have it apart. If you're going to completely disassemble it, I would also replace the oil guides if they look like they've been overheated and/or discolored [they're plastic, and should still be white and not warped looking]. Spin all the other bearings while you're in there and make sure none of the other ones are making noise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy &raquo;</TD></TR><TR><TD CLASS="quote">Where to get a bearing for a y1 transmission of a b16a ? Would this be from a 90-91 integra ?</TD></TR></TABLE>
Open the tranny up, remove the bearing, and measure it's ID, OD, and height in millimeters. Now go to http://www.acuraautomotiveparts.org and look at the different trannies [sometimes 90-91 differs from 92-93] and find the bearing with the right dimensions. If you have trouble, call the number on the website and they can help you.
Old Oct 9, 2005 | 06:42 AM
2point2's Avatar
the 'shitload of oil'.. is it raw oil? or burn on? if it's raw oil it's comming from the round valve cover seals. common problem.
d16efsedan
Apr 8, 2013 08:25 PM
jdmfreak1992
Honda Civic (2001 - 2005)
Jul 26, 2011 04:52 PM
andrewd_89
Transmission & Drivetrain
Feb 10, 2010 04:21 PM
stephen_civic98
Jan 9, 2006 06:05 PM
BI8B
Sep 16, 2003 06:14 AM
