my car doesnt blow.....
Old Sep 18, 2005 | 09:21 PM
civicdust's Avatar
Default my car doesnt blow.....
heater, or ac wont work. i changed all relays and fuses and the ****** still doesnt blow.
am i missing anything? i need AC!!!!
thanks guys/
Old Sep 19, 2005 | 03:55 PM
civicdust's Avatar
Default Re: my car doesnt blow..... (joon)
Old Sep 19, 2005 | 04:01 PM
BloodPressure's Avatar
check to see if you have voltage at the compressor, you should have 12 volts. If you do then check your freon.
good luck,
Justin
Old Sep 19, 2005 | 04:13 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: (BloodPressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BloodPressure &raquo;</TD></TR><TR><TD CLASS="quote">check to see if you have voltage at the compressor, you should have 12 volts. If you do then check your freon.
good luck,
Justin</TD></TR></TABLE>This would be the case if the fan worked but wasn't blowing cold. If I'm reading it right the blower isn't working at all correct? But either way we would need to know what car we are working on so we can help you troubleshoot the entire system. Otherwise we can just give you the general basics..
Old Sep 19, 2005 | 05:10 PM
civicdust's Avatar
Default Re: (HondaFanatic708)
92 cx. everything lights up, but nothing blows. maybe a bad blower?
Old Sep 19, 2005 | 05:16 PM
civiccpedx's Avatar
Default Re: (joon)
i would check into the blower, if you replaced all the fuses that is prolly the case...
check for proper voltage though (dont have correct amount off hand) then see if it is just a bad blower
Old Sep 19, 2005 | 07:17 PM
upgraded's Avatar
blower motor is VERY easy to replace or borrow to test. just 3 8mm screws and one plug just inder the glovebox. Should only take 5 mins with no panels to remove.
Old Sep 19, 2005 | 08:03 PM
civicdust's Avatar
Default Re: (upgraded)
Thanks alot. i will try this tomorrow.
mike1jag
Aug 31, 2007 03:15 PM
M15
Jun 19, 2006 08:04 AM
bxstylez
Oct 7, 2005 05:12 PM
crxsi8
Aug 22, 2005 05:41 PM
n3v3tz
Mar 8, 2004 05:20 PM
