ls swap in eg...which cat and radiator hose do i use?
Old Sep 18, 2005 | 09:15 PM
Kyles ej1's Avatar
Default ls swap in eg...which cat and radiator hose do i use?
im finally gonna get my car back and running and im going ls this time. it has stock header and i have a greddy evo catback. i cant run a test pipe yet cuz i have to go pretty much straight to the ref cuz i gotta smog my car in october so what do i do about a cat? do i have to go to an exhaust shop and have it extended or can i a stock cat and have it bolt up with out any problem?
also which radiator hose would i use for a civic half size radiator?
Old Sep 18, 2005 | 10:26 PM
spreng87's Avatar
Default Re: ls swap in eg...which cat and radiator hose do i use? (93ejay1)
use a 94-95 cat converter and the 94-95 upper hose and bottom also. Um what model is the eg? mine is a VX and I had to swapp out my fuel pump. well I think it was just bad. But yea and you gotta repin the o2 sensor to a 4 plug. I still have to do that.
What I did was just bought a hi flow "fake" cat from ebay for like 30 bucks. I'm looking for a stock one cuz the hi flow is too damn loud and illegal. anyone has an offer?
Old Sep 18, 2005 | 10:33 PM
Kyles ej1's Avatar
Default Re: ls swap in eg...which cat and radiator hose do i use? (spreng87)
i have an ex so i dont gotta worry about that ****
Old Sep 18, 2005 | 10:37 PM
komat's Avatar
any b motor radiator hose will work
Old Sep 19, 2005 | 07:34 AM
Kyles ej1's Avatar
Default Re: ls swap in eg...which cat and radiator hose do i use? (komat)
great but what about the cat?
Old Sep 22, 2005 | 09:21 AM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">great but what about the cat?</TD></TR></TABLE>
Old Sep 22, 2005 | 10:35 AM
the jdmchop's Avatar
i had a ls swap in my coupe before
i used the stock cat from the ls
the swap came with dc headers
so with the dc headers and a oem ls cat i still used my thermal exhaust
Old Sep 22, 2005 | 10:41 AM
Luserkid's Avatar
Default Re: ls swap in eg...which cat and radiator hose do i use? (jdmchop)
Provided your exhaust didnt move location of the stock cat then it should bolt right up and you should be fine with the ref. I used my stock cat and passed.
Old Sep 22, 2005 | 03:43 PM
Kyles ej1's Avatar
Default Re: ls swap in eg...which cat and radiator hose do i use? (Luserkid)
the stock cat from my car or the ls?
Old Sep 22, 2005 | 03:51 PM
ThatsMyEG's Avatar
Why don't you just buy it for a ls motor cause that's what you have, makes sense right?
Old Sep 22, 2005 | 04:06 PM
Kyles ej1's Avatar
Default Re: ls swap in eg...which cat and radiator hose do i use? (ThatsMyEG)
well im getting it swapped in tomorrow so ill have both cats but from what i understand the ls cat on stock headers will come up like 2 inches short of the catback and i have a greddy evo
Old Sep 23, 2005 | 03:59 AM
it shouldnt because why would they make a aftermarket header that is 2'' shorter than an oem one? does not make much sense ha?
i know the gsr one is shorter than the LS could possibkle have the wrong manifold?
as long as you have a LS manifold on your LS motor with a LS cat then you should be fine cause you said you had a ex correct?
Old Sep 24, 2005 | 02:44 PM
Kyles ej1's Avatar
so an ls cat will work without extending it or anything? yea i have an ex
Old Sep 25, 2005 | 03:45 PM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">so an ls cat will work without extending it or anything? </TD></TR></TABLE>
Old Sep 25, 2005 | 03:56 PM
yea it will bolt right up
Old Sep 25, 2005 | 08:40 PM
Kyles ej1's Avatar
what about a gsr cat? will that work too? my friend said any teg cat should work but then i read on here the gsr is shorter. stock ls header
Old Sep 25, 2005 | 08:48 PM
o5mar1's Avatar
just use the ls cat, trust me it will fit. when i did my ls swap i still had the dx stock exhaust system and it fit
Old Sep 25, 2005 | 08:51 PM
riceburnerryan's Avatar
Default Re: (o5mar1)
i donno if GSR stcok header are different than the sotck LS but .. mine bolted up to a stock DX cat ... unless my cat is from an EX
Old Sep 25, 2005 | 08:57 PM
Kyles ej1's Avatar
Default Re: (riceburnerryan)
im just having trouble finding an ls cat but so far ive found like 4 gsr cats, thats y i asked
Old Sep 30, 2005 | 12:01 PM
well my car passes emissions with the stock header and exhuast if thats what you mean
98blackh22lude
Jan 8, 2006 05:53 PM
b_serious
Dec 23, 2005 10:27 AM
JDM00SI
Oct 15, 2005 09:14 PM
shyboi4u
Jan 29, 2005 03:23 PM
