Ls engine---> Gsr swap?
i have about 145K on my ls engine and iam willing to buy a gsr engine how much would it cause me for the engine and where can i find them? do i need to change any other part when i switch to the Gsr?
Search search search...
http://www.hmotorsonline.com has full swaps...
Make sure you do all your research, have you considered rebuilding and boosting your LS?
with the general questions that you are asking I suggest you do your homework before attempting this task.
Heres a big list for you to read on....
https://honda-tech.com/zerothread?id=1230496
good luck
good luck
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
This is how it's going to roll.
A) Your going to spend 3.5-4.5k on a GOOD GSR swap.
B)Rebuild your LS and boost using that same amount and getting more power then your GSR would.
C)LS/VTEC - Cheapest route to go and more power then LS but alittle less then GSR.
D)Finding a new LS for 1200 on HMO or finding one for sale on HT.
Take your choice.
Take your choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahrpr »</TD></TR><TR><TD CLASS="quote">This is how it's going to roll.
Take your choice.</TD></TR></TABLE>
That all depends on how you do it. If you do make it the cheapest route, its also going to be the most unreliable route.. Ls/Vtec is a fickle swap, if not done right and built by someone who knows what there doing, and finely tuned, it wont be as reliable as it can be.. If you do it right, you can make much more power then a GSR..
my ls/vtec is putting down 186whp, 141trq I can rev it to 8200 all day without worrying about a thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">
my ls/vtec is putting down 186whp, 141trq I can rev it to 8200 all day without worrying about a thing.</TD></TR></TABLE>
Is that with a stock block and stock b16 head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">no sir, its a 2000GSR head.
and je pistons rods and bearings.</TD></TR></TABLE>
Then that would explain the numbers. A simple LS/VTEC won't make that much power without the internals you have. Basically you were saying that if you BUILD the motor while doing the swap (along with the work being performed right) you can make more power than a GSR.
Yes, in a sense, but in my personal opinion, in order to build an ls/vtec correctly, you have to raise the compression, which is making it a built motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin »</TD></TR><TR><TD CLASS="quote">Boost It.</TD></TR></TABLE>
i like his answer the best
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">That all depends on how you do it. If you do make it the cheapest route, its also going to be the most unreliable route.. Ls/Vtec is a fickle swap, if not done right and built by someone who knows what there doing, and finely tuned, it wont be as reliable as it can be.. If you do it right, you can make much more power then a GSR..
Very good point also.
