1.6 or 1.8 What would be the difference
Old Sep 18, 2005 | 08:25 PM
Rev2 9K's Avatar
Default 1.6 or 1.8 What would be the difference
First off I am new to this. I put a B16B ctr motor in my 98 coupe. I read that this is a ITR but with a b16 stroke. I bought a ITR crank/ ITR rods with ctr pistons on them already. Would I loose power if I stroked it back to a 1.8, or should I keep it the way it is. Also, would there be clearance problems if I put them in. I check on a couple different calculators, that the compression ratio would be around 12:1. I dont want to blow the motor right now. Any suggestions.
Old Sep 18, 2005 | 08:53 PM
Legend_master's Avatar
Default Re: 1.6 or 1.8 What would be the difference (Rev2 9K)
the ctr motor is not a destroked ITR motor, it is a built up SI motor. Just like the ITR and GSR motors. I think you would have issues with b18 internals in a b16 block. The b16 block is actually shorter then the b18 blocks and would make the pistons hit the head.
Old Sep 18, 2005 | 09:18 PM
strsi's Avatar
Default Re: 1.6 or 1.8 What would be the difference (Legend_master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legend_master &raquo;</TD></TR><TR><TD CLASS="quote">the ctr motor is not a destroked ITR motor, it is a built up SI motor. Just like the ITR and GSR motors. I think you would have issues with b18 internals in a b16 block. The b16 block is actually shorter then the b18 blocks and would make the pistons hit the head.</TD></TR></TABLE>
wrong. the b16b uses a b18 block with less stroke. its not a built up "si" motor cuz it doesnt even use the same block casting as the b16a
Old Sep 18, 2005 | 09:23 PM
Rev2 9K's Avatar
Default Re: 1.6 or 1.8 What would be the difference (strsi)
I thought it was 1.8. My question is, the b16b block with the ITR crank/ ITR rods and CTR pistons, Would they work or hit? It looks to be aroun 12:1 compression.
Old Sep 19, 2005 | 09:25 AM
97L-esVeeTeg's Avatar
it'll work fine. The b16b and the b18 blocks share the same deck height. CR may end up being a little higher that 12:1
Old Sep 19, 2005 | 10:24 AM
Honda Bull's Avatar
Default Re: 1.6 or 1.8 What would be the difference (97L-esVeeTeg)
But it is a destroked B18C. It's a 1.6 crank and rods in a 1.8 block pretty much.
Your setup would work. And you won't lose power. No replacement for displacement.
Old Sep 19, 2005 | 12:30 PM
D-Rob's Avatar
Default Re: 1.6 or 1.8 What would be the difference (HondaBullSQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaBullSQ &raquo;</TD></TR><TR><TD CLASS="quote">
Pretty much. Because of the taller deck height, it uses longer rods than your normal B16, thus creating a better rod-to-stroke ratio.
That's why you can rev the **** out of a B16B.
Old Sep 20, 2005 | 07:31 AM
Jason.H.'s Avatar
WOW ur stupid. dont talk if you dont know what ur talking about. this site does not put up with false information.
Old Sep 20, 2005 | 07:50 AM
Default Re: 1.6 or 1.8 What would be the difference (hondagod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondagod &raquo;</TD></TR><TR><TD CLASS="quote">
...this site does not put up with false information.</TD></TR></TABLE>
I just thought that was funny
Old Sep 20, 2005 | 10:40 AM
Used2beAb16's Avatar
The site doesnt put up false informations its the posters that dont know what they are talking about.
Old Sep 28, 2005 | 07:02 AM
Jason.H.'s Avatar
Default Re: 1.6 or 1.8 What would be the difference (Used2beAb16)
Exactly. thats what i said. i was telling him if he doesnt know for sure what hes talking about then he shouldnt say anything.
Teamdiesel
Jul 21, 2007 02:59 PM
SmurfDA
Sep 28, 2004 10:29 PM
Rob Dizzle
Mar 1, 2004 11:30 AM
F120man
Sep 8, 2001 11:40 PM
