difference of CTR and ITR motor?
Old Sep 7, 2001 | 02:23 PM
F120man's Avatar
New User
Default difference of CTR and ITR motor?
whats the difference between the civic R motor and Integra R motor? i know the displacement is difference , but what about the internals and tranny? which motor would you prefer inside a EG?
Old Sep 7, 2001 | 02:32 PM
sgT's Avatar
sgT
Default Re: difference of CTR and ITR motor? (F120man)
Crank rods and pistons make 1.6L 10.8:1 CR.
CTR and ITR blocks themselves are the same. As are the cylinder heads.
Intake cam is different also.
Trans is same as USDM ITR and 96spec R transmission.
1.8L B18C is always better.
Old Sep 7, 2001 | 09:49 PM
Alexis's Avatar
New User
Default Re: difference of CTR and ITR motor? (sgT)
What about a ITR motor with CTR Pistons & CTR Intake Cam. How much better would that be from stock ITR motor?
Old Sep 7, 2001 | 09:57 PM
Racer-X's Avatar
Default Re: difference of CTR and ITR motor? (Alexis)
The CTR carries the longer gear ratios of the SiR not the ITR's info via Hyper Rev.
Old Sep 8, 2001 | 06:27 AM
Dipshit Dan's Avatar
Default Re: difference of CTR and ITR motor? (Racer-X)
No, CTR has same as 96 spec/USDM R transmission. Obviously the ECU is a bit different to deal with all the changes that Stephen mentioned.
Old Sep 8, 2001 | 11:23 PM
Racer-X's Avatar
Default Re: difference of CTR and ITR motor? (God)
Actually no they didn't in 97-98 CTR used the 97-98 SiR trans with 2-3-4 gear ratio shorten. This is the Main reason the CTR 98' loses to ITR 98' in 1/4 mile run. Which can be seen in the Best MotoRing vol1 R legend edition and also mentions the SiR trans when the test concludes.
97-98 Civic Type R: specs http://www.honda.co.jp/HOT/ModelData...-708/r_sy.html
95-99 Integra SiR 3-door: specs http://www.honda.co.jp/HOT/ModelData...ta/3sir_g.html
95-99 Integra Type R 3-door: specs http://www.honda.co.jp/HOT/ModelData...ata/index.html
Old Sep 8, 2001 | 11:40 PM
H-PIMP's Avatar
I think Racer X settled that one.
airmaxbri
Oct 5, 2007 05:38 AM
poormans_typer69
Nov 13, 2006 06:22 AM
Rob Dizzle
Mar 1, 2004 11:30 AM
eRACING
Sep 25, 2003 08:22 PM
Looose_R
17
Jul 26, 2002 06:27 PM
