power window conversion on a 93 hatch
is there a how-to on puttin power windows on a 93 hatch? For the people that have done this is it hard to wire up or should i just get someone to do it for me?
it's actually pretty easy, we did a manual to power window conversion on his 95 ej. all you really have to do is swap out the manual window regulator and but the power one in and bolt it up. just be careful NOT TO DROP THE GLASS. next is just your wiring which really isn't even that tough. all in all it's fairly easy.he got his whole manual to power swap for like 50 bucks, and that was with the door panels and everything.
okay, i have a problem, i bought my hatch with the power window set up in stalled. Both windows were working perfectly fine except for the master switch for the passenger side window wouldnt roll that side down, I would have to reach over to hit that switch. Never mind that part, thats a whole different situation for now. But a couple nights ago, I was driving down to the gas station, and my windows were working perfectly fine. I woke up the next day and none of them roll down anymore.
what should i check for? I pulled the fuses and there are no breaks. I need to know, I cant drive without having a window down. Please help me? I want to pull the relay, but i if thats bad I dont think I have the money to get a new one anytime soon. But what if it isnt the relay? What else should I check? PLEASE help me!!!
How long have you had this car? The previous owner probably had wired the left and right windows to a constant power when the ignition is turned on. Instead of doing the full swap. Hopefully they installed inline fuses.
Anyhow, check to see if you're getting any power to the switches. I have never heard of a relay going out unless it was pulled from a junked car that was sitting in the rain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bogoys »</TD></TR><TR><TD CLASS="quote">okay, i have a problem, i bought my hatch with the power window set up in stalled. Both windows were working perfectly fine except for the master switch for the passenger side window wouldnt roll that side down, I would have to reach over to hit that switch. Never mind that part, thats a whole different situation for now. But a couple nights ago, I was driving down to the gas station, and my windows were working perfectly fine. I woke up the next day and none of them roll down anymore.
what should i check for? I pulled the fuses and there are no breaks. I need to know, I cant drive without having a window down. Please help me? I want to pull the relay, but i if thats bad I dont think I have the money to get a new one anytime soon. But what if it isnt the relay? What else should I check? PLEASE help me!!!</TD></TR></TABLE>
i justed wired my power window and everything works great even the master switch for the passenger side.
but if it worked the day before like you said and now it doesnt it might be a relay because both fuses cant just go out at the same time. well maybe it can iono.
you should get a friends relay and plug it in and see if it works.
check fuses 5 and 8 under the dash.
and do you know if the power window was installed with the floor harness or did the guy installed it his own way? because i wired it up my own way because i ddint have a floor harness.
I can help you wire everything up if you need help.
what should i check for? I pulled the fuses and there are no breaks. I need to know, I cant drive without having a window down. Please help me? I want to pull the relay, but i if thats bad I dont think I have the money to get a new one anytime soon. But what if it isnt the relay? What else should I check? PLEASE help me!!!</TD></TR></TABLE>i justed wired my power window and everything works great even the master switch for the passenger side.
alright, i checked and it is a floor harness, the wires are stock colored wires..., i wanna check the relay but its been raining a lot lately, and I wouldnt know which harness it is... I dont knwo which one to pull exactly.
alright.. I figured out what was wrong with my windows! stupid loose wire. Now for the fun, ive tried direct connectign the blu/yel and blu/grn wire to the one on the master switch and it still wont roll ym pass side windows down!
i need help!
i need help!
its best to solder so no wires can come looses. i hate those clamp things, they suck ***.
EDIT -
for those of you who dont have a floor harness like i did.
here is a look at the back of the fuse box. If you dont have a floor harness hook up the wires to the back of the fuse box like i did.
Modified by tdo at 9:58 PM 10/15/2005
EDIT -
ok i know this is old but i gotta 94 hatch and a ex coupe that i bought for parts stripped and sent to the yard, i cut the inside harness as least as possible from the coupe. like i got the WHOLE thing. but i cant figure out how to get it in my hatch. i finished putting the lock motors and window motor/regulator in
but is it just plug and play? like is the hatch PREwired for windows and locks? meaning can i just run the harness thru the door, thru the body, and plug it into the harness i got from the coupe and just plug that in? or is it easier to just cut the harness and splice? and if so, are the 2 harnesses the same colors so i can just match colors from the 2??..but that would mean the hatch is prewired...? cuz if not how else is there any power going to the passenger side??
help, cuz the window is all the way up and the glass isnt on... i gotta get the power to it to lower the regulator so i can install the window... and its ******* COLD..
808_devil
Nov 23, 2010 07:28 PM
gleinz
27
Mar 2, 2003 06:06 PM
