Im new and have a question
Old Sep 18, 2005 | 04:17 PM
nmudrumline's Avatar
Default Im new and have a question
Hey guys, I have an H22 swap into an EG civic. The engine is a 93 and the car is a 92. My radiator is busted, and I need to get a new one. My friend told me to get a fluidyne, but I am unsure if I need to get one for a civic, or for an H22. Also, is there a better radiator then fluidyne? Lemme know guys, thanks for your help.
Old Sep 18, 2005 | 05:48 PM
Mugen112's Avatar
Just get a stock gsr unit. Dual core. With the h22 the civic radiator would be OK, but a gsr would be better. Go with Fluidyne if you have the money, but they all cool the same way, the quality is just better.
Old Sep 18, 2005 | 06:23 PM
v4lu3s's Avatar
RTFM
only get teh gsr radiator if you dont have ac and dont mind fabricating mounting tabs for the radiator.
i personally use a del sol vtec radiator and it works fine in texas summers in bumper to bumper traffic.
Old Sep 18, 2005 | 10:23 PM
Default Re: (Mugen112)
if i were to buy the fluidyne, would i get it for a civic or h22? im guessing an h22 correct? is a koyo radiator good? like some of the ones they have on ebay?
Old Sep 19, 2005 | 04:39 AM
v4lu3s's Avatar
RTFM
if you buy an "h22" one you will be buying a prelude radiator....
Old Sep 19, 2005 | 03:50 PM
Default Re: (v4lu3s)
yeah...i know...which would technically cool the engine better then one for a civic...i dunno....i think im gonna buy a koyo radiator for a civic or one for a del sol vtec as afformentioned, unless anyone really knows this is a bad idea.
Old Sep 19, 2005 | 05:07 PM
hondaxsimike's Avatar
Default Re: (nmudrumline)
buy the one that fits yer car. it will save you headaches in the end. honda are really good about cooling so even if its a lil smaller it should do just fine.
Old Sep 20, 2005 | 03:15 PM
Anthony's Avatar
Mr. Fuch-yu
Default Re: (hondaxsimike)
The way i see it is... your radiator is busted, logically it was a civic radiator, replace it with a civic radiator. You can replace it with a stock unit or you can get a fluidyne unit, in either case make sure the radiator you order is intended for a civic not a prelude. The gsr unit would work but as someone mentioned earlier mounting it may pose a problem and a civic radiator will be adequate. For simplicity's sake go with the civic radiator. Hope this helps.
Varano44
Sep 17, 2008 05:14 AM
S2k ALeN
Apr 15, 2004 11:25 PM
