This is TURBODEEZ with a serious prob on the D
Old Sep 18, 2005 | 01:46 PM
EntuneCrx's Avatar
Default This is TURBODEEZ with a serious prob on the D
Ive been breaking in my new D series motor that i built and all of a sudden the motor doesnt seem like its firing correctly. It will idle great and it will rev good when not moving, but once i start driving it starts sounding like a lawnmower or like its missing a little bit but i cant see to find out whats wrong with the damn thing. Its getting tuned with Turboedit FYI. Another scenario is when i floor it, the motor will rev really slow, but when i give it about 40% throttle it revs as it should. All of this just suddenly happened one morning when i woke up. It also seemed to coordinate with getting some gas from a new gas station in the area. Mainly the problem is when the car is under load, it doesnt seem to respond well to throttle changes. FYI it was running fine the first day i started it, it ran like a normal car.
Old Sep 18, 2005 | 02:05 PM
GOLDBERG's Avatar
Default Re: This is TURBODEEZ with a serious prob on the D (EntuneCrx)
timings off
Old Sep 20, 2005 | 08:32 AM
TURBODEEZ's Avatar
it doesnt seem to be the timing because the motor was running on the same program for a week and it was fine, now the motor is acting like its misfiring under load. It sounds like its dropping a cylinder.
Old Sep 25, 2005 | 08:28 PM
Humble Performance's Avatar
Default Re: (TURBODEEZ)
Check your spark plug wires.
Old Sep 26, 2005 | 08:05 AM
MONSTERZC's Avatar
Default Re: (8secEg)
i would do like the others say id check your plug wires and plugs id also check the timing out anyway. the timing belt doesnt care what program you ran week ago if its loose it will slip and if it does slip you may have bent a vavle or vavles also check your wiring at the coil to make nothing came loose your is loose
arziffel
Feb 8, 2012 03:54 PM
CountryHonda
May 29, 2008 07:01 PM
91DApwr
Dec 28, 2005 07:53 AM
curiousgpnoy
Feb 16, 2005 12:16 PM
