ECU ground
Old Sep 18, 2005 | 12:24 PM
red97EX's Avatar
Default ECU ground
anyone know how i would go about checking the ground/grounds for the ECU? basically, which color wires are power supply and ground wires on the harness?
it's an OBD2
Old Sep 18, 2005 | 01:39 PM
Chiovnidca's Avatar
Default Re: ECU ground (red97EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red97EX &raquo;</TD></TR><TR><TD CLASS="quote">anyone know how i would go about checking the ground/grounds for the ECU? </TD></TR></TABLE>
It's the one bolted to the t-stat housing. Make sure it has a clean/tight connection.
Old Sep 18, 2005 | 02:50 PM
red97EX's Avatar
Default Re: ECU ground (Chiovnidca)
thanks... i'll take a look at that
i just want to check every possible thing before i put a new ECU in.... i'd hate to just keep having them go bad if i have some wiring issues
Old Sep 20, 2005 | 09:23 AM
red97EX's Avatar
on the ECU Harness (OBD2) which wires are ground wires? i.e. which color wires need to have continuity to the chassis?
on the ECU pin outs, would it be all of the locations with a "G" at the end of the abbreviation?
finally, does anyone know of a link where i can find out what all the abbreviations on the ECU pin out diagram mean?
thanks again for the help.
Old Sep 20, 2005 | 10:42 AM
red97EX's Avatar
found it here....
http://www.phearable.net/tech/wiring/pinouts2.htm
in case anyone else would need to use it as a reference
Teg_Your_It
Jun 17, 2006 05:08 PM
huge230
Sep 3, 2005 08:03 AM
mockujin
Nov 17, 2002 06:06 AM
