kamikaze or dc?
Old Feb 28, 2002 | 01:37 PM
batboyvaj's Avatar
Default kamikaze or dc?
i've been looking at the prices and stuff...and since the dc jdm header doesn't bolt onto a gsr, i was looking at the kamikaze. its a 4-1 design with a 2.5" collector just like the jdm dc header. whats your opinions on these headers? all i have right now is aem/apexi ws...after the header i'm going to get itr cams and gears. how do these headers compare to dc? anyone have these headers?
Old Feb 28, 2002 | 02:14 PM
nfn15037's Avatar
Default Re: kamikaze or dc? (batboyvaj)
Kamikazee header is mainly for supercharged cars. I havent heard anything good about it on NA cars. Just get the DC JDM 4-1 or the ITR 4-1.
Old Feb 28, 2002 | 02:39 PM
batboyvaj's Avatar
Default Re: kamikaze or dc? (nfn15037)
what all do i have to modify to get the jdm header to fit my 2001 gsr?
Old Feb 28, 2002 | 03:59 PM
batboyvaj's Avatar
comon guys...what other headers in the range of 400 are good for the money. greddy? comparable to dc? if i can't get the jdm 4-1...would the reg dc 4-1 be better than a 4-2-1 design?
Old Feb 28, 2002 | 04:04 PM
RedStarGsr's Avatar
dc jdm 4-1 is only $289 from http://www.inlinefour.com have fun w/ that crossmember though
Old Feb 28, 2002 | 08:04 PM
nfn15037's Avatar
Default Re: kamikaze or dc? (RedStarGsr)
Crossmember?? Not on G3 Integras, it fits fine.
Old Feb 28, 2002 | 10:48 PM
SMSP's Avatar
For that money get the DC JDM or ITR JDM header. Then you need a 2-1/2" cat made to fit your year vehicle and everything is a bolt on deal. The Kami header for with the 2-1/2" collector is the same length as the JDM headers. They do make a Kami header that bolts onto the stock ccat but the down pipe goes from 2-1/2" to 2", but you really don't want the Kami header for NA.
Old Mar 1, 2002 | 06:31 AM
threatcon13's Avatar
New User
when i had that header(DC) I just had a flange made..if I were to do it now I would just get JDM ITR 4 to 1 and a 2.5 cat so it bolts right up.
Old Mar 1, 2002 | 08:28 AM
batboyvaj's Avatar
Default Re: kamikaze or dc? (SMSP)
where do i buy a good cat that isn't so expensive so it'll bolt up? what about the reg dc 4-1. or a greddy or apexi, comptech?
Old Mar 1, 2002 | 08:56 AM
New User
if youre planning on making good all motor power, the 2.5 inch collector and 2.5 inch cat will be benificial..you can get a 2.5 inch cat from carsound...i think ben@importparts has them.
Old Mar 1, 2002 | 09:36 AM
Rory Breaker's Avatar
Default Re: kamikaze or dc? (ALLMOTORDC2)
We offer OEM JDM and DC JDM 4-1 packages including a bolt-on Carsound Cat, or the cats seperately. Drop me a line if you need pricing info.
The Kamikaze will work on a non-SC car, its primary-design just makes it more beneficial to SC setups, thats all. Kamikaze wouldnt be on the top of my list in terms of quality, unfortunately, so if you're not SC'd, youre better off with another brand, IMO.
Old Mar 1, 2002 | 10:48 AM
batboyvaj's Avatar
Default Re: kamikaze or dc? (newgsrdriver)
i was looking at the test done during the header test and the comptech header did as good as the jdm 4-1. and it bolts up? what do you guys think of this header?
Old Mar 1, 2002 | 09:40 PM
batboyvaj's Avatar
ok guys...i think i'm gonna get a migwelded comptech. its a 4-2-1 "steeped" design. its a kewl design. its like 389 shipped. i hope its comparable to dc
Old Mar 2, 2002 | 12:34 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
for that $$, get the DC JDM or OEM JDM 4-1...both **** on the comptech
Old Mar 2, 2002 | 03:04 AM
SMSP's Avatar
The Comp Tech header wasn't a real bolt on for the header test. It used a special stepped test pipe in order to bolt up to the full 2-1/2 exhaust. Don't expect the same gains by bolting it up to the stock cat/exhaust. If you want to get something just so that it will bolt up to the stock location then get the DC 4-2-1 since the primaries are bigger on the DC (1-5/8") with 1-3/4" secondaries. The CompTech has 1-1/2" x 1-5/8" stepped primaries. But if you want something that performs better get the DC JDM or ITR JDM for $100 more.
Old Mar 2, 2002 | 05:52 AM
1fastGSR's Avatar
New User
just get the ITR JDM and buy a cat from SMSP. I compared both the JDM ITR and DC JDM and the DC looked very low quality compared to the JDM ITR. To me, the JDM ITR was worth the extra $100. You can also use heat shields with the JDM ITR making it look like stock and the heat shields keep the temperature under the hood low.
Old Mar 2, 2002 | 06:56 AM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
He'd have the same problem with a JDM header since his exhaust is probably
2 1/4" anyways. So he'd have a restriction at the exhaust now vs. the header (on the header test for the Comptech 4-2-1)...he'd still have a restriction. The Comptech 4-2-1 at least would be a straight through design; stick a high flow cat on there and that's a pretty comparable system to that used on the header test (minus the exhaust part)...and the JDM setups that a lot people run here aren't even the same as found on the test anyways (due to 2 1/4" exhaust)...if only 2 1/2" exhausts were more common.
white_db8
Jun 18, 2007 12:59 AM
TYspeK EH2
Dec 10, 2003 08:51 PM
SICKSOLSI
Jun 29, 2003 06:55 PM
cichlid
Mar 22, 2003 10:59 PM
