3 distributors later and still a code 9 CYP....
Old Sep 18, 2005 | 09:01 AM
gutted's Avatar
Default 3 distributors later and still a code 9 CYP....
i have a 91 HF with a b18 swap and converted to obd1 with a rywire conversion harness and using a chipped p28. im using an obd1 dist that i de-pinned and am using obd0 plugs. car starts fine but i keep getting code 9 for cylinder position sensor (CYP). i ohmed out the 2 wires for the CYP at the dist and they were within spec (398ohms and spec is between 300ohms-700ohms). checked to see if theres a break in the wire all the way to the ecu. no breaks. i went through 3 good dist and still nothing. i even tried swapping the 2 wires on the dist for the CYP thinking i might have swapped them when i re-pinned the dist, but still nothing. im really really stumped
Old Sep 18, 2005 | 11:06 AM
dr_latino999's Avatar
Default Re: 3 distributors later and still a code 9 CYP.... (gutted)
Try running a wire straight from the ecu to the distributor, this for some reason seems to kill of my electrical ghosts.
Old Sep 18, 2005 | 12:09 PM
gnar kill's Avatar
Default Re: 3 distributors later and still a code 9 CYP.... (dr_latino999)
bump ....I have exact same problem in my obd 1 mini me swap
Old Sep 18, 2005 | 01:04 PM
gutted's Avatar
Default Re: 3 distributors later and still a code 9 CYP.... (gnar kill)
just tried that and i still have the CEL
Old Sep 18, 2005 | 01:10 PM
RCautoworks's Avatar
What about the wiring by the ecu ? How does that look Arthur ?
Old Sep 18, 2005 | 01:11 PM
Chiovnidca's Avatar
You sure your wires are going to the right ecu pins? Some of the obd0 to obd1 conversion harnesses switch them around.
Old Sep 18, 2005 | 01:58 PM
Mach69's Avatar
Trying Re-soldering your connections at the ecu (before the conversion harness).
Thats what I did and it solved my code 9 with I did my mpfi swap.
Make sure the conversion harness wiring is going to the correct place.
Make sure the distributor plug connection is good.
Old Sep 18, 2005 | 02:24 PM
gutted's Avatar
Default Re: 3 distributors later and still a code 9 CYP.... (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">What about the wiring by the ecu ? How does that look Arthur ?</TD></TR></TABLE>
if there were any breaks in the wires, when i wired the 2 CYP wires straight from my dist to my ECU that should have fixed it. correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">You sure your wires are going to the right ecu pins? Some of the obd0 to obd1 conversion harnesses switch them around.</TD></TR></TABLE>
like what? i thought they were all routed the same way.
man i hate electrical problems
Old Sep 18, 2005 | 02:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted &raquo;</TD></TR><TR><TD CLASS="quote">
But are you sure there in the right spot ?
Old Sep 18, 2005 | 03:10 PM
gutted's Avatar
ok i went over it again and found out that the orange wire (on the engine harness that plugs to the dist) connects to B10 (CKP P *according to hasport*) then from my conversion harness that connects to B11. then the white wire goes to B12 (CKP G) then to B12. so it looks like CKP signal is getting fed to my CYP signal. going to check if they are crossed vice-versa as well
Old Sep 18, 2005 | 03:20 PM
gutted's Avatar
so yah the wires for the CKP cross the CYP wires through my conversion harness. im going to try swapping them out and see if it fixes my problem.
BTW thanks awhole bunch for the quick responses and help from everyone
Old Sep 18, 2005 | 07:59 PM
gutted's Avatar
well i crossed them now i have a code 4 for CKP sensor
any other tips or tricks would be great
Modified by gutted at 11:01 PM 9/18/2005
Old Sep 19, 2005 | 05:56 AM
CrazyKoreanCrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted &raquo;</TD></TR><TR><TD CLASS="quote">well i crossed them now i have a code 4 for CKP sensor
Modified by gutted at 11:01 PM 9/18/2005</TD></TR></TABLE>
Whats the wiring color? To Obd-0 to Obd-1
*Note: I have my crx with a b16a obd1 and had the same problem. I still have my write-up on paper. I just need to see the what wire colors are connected.
Also "rywire conversion harness" came with the instru.? Right?
And another thing to the car runs with the code flashing and you can drive it around until it the dizzy over heats, then the car would shut-off and wouldnt move. That happen to me twice.
Old Sep 19, 2005 | 08:45 AM
Rywire's Avatar
Default Re: 3 distributors later and still a code 9 CYP.... (CrazyKoreanCrx)
Give me a call today, the harness is pinned different than hasport, so dont go by that. Make sure you follow the directions to a T. If you still have troubles, or you have allready swapped wires and have no idea where they go then give me a call, I will tell you how to do it.
Ryan
Old Sep 19, 2005 | 08:51 AM
Default Re: 3 distributors later and still a code 9 CYP.... (droppedcrxsi)
Dude its probably four wires
Old Sep 19, 2005 | 10:05 AM
gutted's Avatar
ok im going to put the pins back to how they were when i get back from work. does anyone have the instructions they can show me cause i lost those. i want to make sure i didnt miss something in the instructions. for me for not keeping or reading the instructions
Old Sep 19, 2005 | 10:14 AM
NikoZai's Avatar
If you're talkin about the Rywire instructions, they're on the website.
Here's the dpfi to mpfi - http://www.rywire.com/dpmpfi_i.shtml
You should really just call us though, the # is on the website.
Old Sep 19, 2005 | 05:31 PM
gutted's Avatar
Default Re: 3 distributors later and still a code 9 CYP.... (NikoZai)
cool should i ask for anyone in specific?
Old Sep 21, 2005 | 09:41 PM
gutted's Avatar
can you guys just send me the pinout diagram along with the full instructions that come with an OBD0-OBD1 conversion for an hf/si? the diagram will help me out alot so i dont have to go by someone elses pinouts and find out you guys just used a diff location. thanks. ill try and call you guys tommorrow but i have work in the afternoon and by the time i get off you guys are closed.
Old Sep 22, 2005 | 12:02 AM
Ok I might have it right I dont know. But here it is in my-point of view
Obd0 Obd1
peach(white) yellow/green
blue/green blue/green
orange peach(orange)
orange/blue white/blue (wrong)
blue/white(blue/yellow) blue/white(blue/yellow)
peach(white) white
white/peach(white/blue) peach/blue(orange/blue)((wrong))
Hopefully switch the wrong one's around and it should clear the code. If not leave a post on the code and I'll look at my books for it again.
Old Sep 25, 2005 | 04:16 PM
gutted's Avatar
well i finally got my car started today. dont know how but it does. car idles near perfect with my obd0 dist & ls ecu but once i switch to obd1 thats where i have problems. my dist plug is wired up correctly but my car wont hold idle and the car only starts rarely.
i started a new post since i got rid of my CEL
https://honda-tech.com/zeropost?cmd=fshow&id=3
Modified by gutted at 7:04 PM 9/25/2005
Old Oct 4, 2005 | 05:12 PM
1SlowB16EF's Avatar
did you resolve the problem i am been reading and very interested i am going through the same problem now!
Old Oct 4, 2005 | 11:06 PM
Rywire's Avatar
Default Re: (1SlowB16EF)
If you call me I can do some VERY easy tests over the phone. Its that easy... Stop posting this crap, and call. Ill have your car diagnosed in no time
Old Oct 4, 2005 | 11:32 PM
Dancing is Forbidden's Avatar
Default Re: (droppedcrxsi)
I had to change out my entire shock tower harness for my Code 8 to go away. It was happening on three different engines, countless ecus, dist. and engine harnesses.
Old Oct 5, 2005 | 08:11 AM
rioninja's Avatar
Here is a Diagram I Made. This is what it should be at the ECU. Just check it with a voltmeter.
slow_low_eddie
Mar 2, 2014 12:06 AM
Tensa_Zangetsu
Feb 28, 2009 05:12 PM
crxvtecturbo
11
Sep 2, 2006 12:05 PM
HatchWarehouse
Apr 18, 2006 03:00 PM
91civicEX
15
Sep 3, 2003 10:33 PM
