skunk 2 intake manifold idles at 4000
i just replaced the manifold last night and not it reves up to 4000 i think that it is the iac valve or sensor but i dont know how to clean it if it is if someone can help me i would really apreciate it
which vacume do you think it is also i didnt have a long enough hose for the one big vacume on the front of the manifold so i left it off , the one that comes up between the piping. do you think that is the problem. and if it is should i temperarily plug it up
i would check for vacuum leaks first.
couldn't it also have something to do with the tps, doesn't that effect idle? correct me if im wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18danger »</TD></TR><TR><TD CLASS="quote">which vacume do you think it is also i didnt have a long enough hose for the one big vacume on the front of the manifold so i left it off , the one that comes up between the piping. do you think that is the problem. and if it is should i temperarily plug it up</TD></TR></TABLE>
yes, thats the problem, atleast go get a vacuum plug and stick it on there
japrex
Dec 22, 2004 06:42 PM
