timing belt cover --- is it needed?
Old Sep 18, 2005 | 06:21 AM
douglaslovin's Avatar
Default timing belt cover --- is it needed?
It was my timing belt cover that was warped and rubbing on my timing belt which caused it to shred up
can i just take the cover off and run my car like that? Or is that not good?
Old Sep 18, 2005 | 06:29 AM
Curtis2kul's Avatar
Default Re: timing belt cover --- is it needed? (douglaslovin)
Ive seen people run without one which is ok but i like to have mine on just because i wouldnt want anything falling into there.
Old Sep 18, 2005 | 06:30 AM
downeyballz's Avatar
the bottom portion is needed to time the motor
Old Sep 18, 2005 | 06:52 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by douglaslovin &raquo;</TD></TR><TR><TD CLASS="quote">
can i just take the cover off and run my car like that? Or is that not good?</TD></TR></TABLE>
I consider that "not good". If a rock or something gets kicked up into the belt it can knock it out of time.
Old Sep 18, 2005 | 07:16 AM
BlueShadow's Avatar
Default Re: timing belt cover --- is it needed? (downeyballz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">the bottom portion is needed to time the motor</TD></TR></TABLE>
I've been running my B18C without the lower cover for a little over a year now. I just line up the actual sprocket or "tooth" on the crank gear with the TDC mark on my block.
Old Sep 18, 2005 | 07:18 AM
Default Re: timing belt cover --- is it needed? (BlueShadow)
yeah you can fo that too, but i think its harder because its harder to see, and how do you line up the tooth on the crank gear if the pulley is on?
Old Sep 18, 2005 | 07:41 AM
well my lower timing cover is getting ate up by the belts from the alternator.. its like chewing straight threw the cover... and pushing the cover against the pulleys and timing belt
thats what caused it to shred
whats the chance of a rock actually shooting up into a pulley? Slim to none right?
Old Sep 18, 2005 | 09:11 AM
IGotNoSwap's Avatar
i run just the bottom part of it on. that way in rain or so, nothing flys up in there.
Old Sep 18, 2005 | 09:20 AM
Adam.C's Avatar
just pick up another cover, you dont want to have bent valves or anything like that. Its good insurance
Old Sep 18, 2005 | 11:24 AM
1point5CRX's Avatar
Default Re: timing belt cover --- is it needed? (orangerex04)
i dont run any cover either, never had any problems in about 2 years. ive been through all sorts of road conditions and havent had any trouble
Old Sep 18, 2005 | 08:14 PM
Adam.C's Avatar
Default Re: timing belt cover --- is it needed? (1point5CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point5CRX &raquo;</TD></TR><TR><TD CLASS="quote">i dont run any cover either, never had any problems in about 2 years. ive been through all sorts of road conditions and havent had any trouble</TD></TR></TABLE>
Yur lucky
Old Sep 18, 2005 | 08:50 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">yeah you can fo that too, but i think its harder because its harder to see, and how do you line up the tooth on the crank gear if the pulley is on?</TD></TR></TABLE>
You can still see the teeth on the gear even with the pulley and belt on. I found out that the TDC marking on my pulley lines up perfectly with the center of one of the teeth. I line up the center of that tooth with the TDC marking on the block.
Old Sep 18, 2005 | 08:59 PM
turboZChatch's Avatar
I only run the lower cover also same with my friend and so far so good.....
Old Sep 18, 2005 | 09:23 PM
sam385's Avatar
keep both timing covers on for safety; this part of the car causes enough problems inherently without exposing it to the possibility of rocks, water, salt, etc. getting into the mix.
Old Sep 18, 2005 | 09:38 PM
sporkcrx's Avatar
Default Re: timing belt cover --- is it needed? (sam385)
How do you adjust your ignition timing with no bottom cover?
poormans_typer69
Oct 17, 2007 07:32 PM
924doorEG
12
Sep 6, 2007 07:44 AM
B16b-EJ8
Mar 1, 2007 09:02 AM
rollydc69
Jan 8, 2006 12:15 PM
dubnine
Mar 25, 2004 05:24 AM
