Pacesetter Catback Exhaust System ~ Good Or Bad?
Old Sep 18, 2005 | 12:01 AM
itsmedavid's Avatar
Default Pacesetter Catback Exhaust System ~ Good Or Bad?
is the Pacesetter Catback Exhaust System good or bad? i heard its low when cruising and a nice low tone when reving it and plus i heard it gets rusty fast too.
Old Sep 18, 2005 | 07:25 AM
HxClude's Avatar
Default Re: Pacesetter Catback Exhaust System ~ Good Or Bad? (itsmedavid)
Had one on my old Accord. Sounded good - same volume as stock but deeper pitch. And yeah, it rusted out fast.
If you're on a tight budget, the Apexi WS is more durable and you can get it for ~$360 if you shop around.
Full stainless steel is your best bet though (Greddy, Tanabe, Thermal, Skunk, Invidia, etc., etc.) - drop $500 now and you'll never need another exhaust
Old Sep 18, 2005 | 07:36 AM
chitownrida's Avatar
had one as my first exhaust. its not bad sounding but it starting rusting and broke after about 1 yr (chicago winters)
the only thing i hated that it looks kinda stock
then went with apex ws. never looked back
dont get it unless you can get it for less than $175
Old Sep 18, 2005 | 08:59 AM
itsmedavid's Avatar
Default Re: (chitownrida)
damn where can u find it for less than 175? i looked around and they are atleast 200 w/o shipping (96 honda prelude si)
Old Sep 18, 2005 | 09:01 AM
itsmedavid's Avatar
Default Re: (itsmedavid)
doesnt 92-96 prelude have the save piping? cause im looking and they only have 92-93 so im guessing 96 will fit too right?
Old Sep 18, 2005 | 09:07 AM
itsmedavid's Avatar
this is the cheapest i have seen and i already tried ebay
http://www.performancepartz.co...=1949
Old Sep 18, 2005 | 04:04 PM
HxClude's Avatar
Unless you need a new exhaust to sell the car, save up for the Apexi WS/WS2.
$220 shipped for a system that only lasts ~1 year . . . well . . . I wouldn't do it
Old Sep 18, 2005 | 04:46 PM
driftNWC's Avatar
totally, the world sport is of a much higher quality
Old Sep 26, 2005 | 02:34 PM
InvaderTrax's Avatar
Anyone used one of these in the south? I live in Knoxville and things don't rust as quickly as places like Chicago. My old exhaust is completely rusted out (counted 5 leaks today, including the joint between the cat pipe and resonator). I really like the look of the dual tip Pacesetter, and the user reviews say it gives good performance. I don't like the look of one 4" tip, so if anyone can recommend either this or a similar dual tip exhaust, that'd be wonderful ('92 H23)
Old Sep 26, 2005 | 03:08 PM
f22b_dohc's Avatar
its not worth it i used to have a pace setter header and it rusted and cracked
Old Sep 26, 2005 | 03:31 PM
MNsnowdaboy's Avatar
Why would you want to spend 175-200 and only last 1 year or so. Spend the extra money and that exhaust will probably last longer then you keeping your car.
Old Sep 26, 2005 | 03:47 PM
Well, I can't afford anything higher end, and I've got 6 holes in my current exhaust that can't be patched (too rusty), so it's pretty much my only option. Since the biggest problem people are having with the Pacesetter is rust, I think if I just give it a good two coats of high heat paint (900 degree max, way higher than it gets at this part of the exhaust) that it'll hold up. I was the guinea pig for the XTD clutch and flywheel combo, and that worked out well enough. Maybe this will too *hopes*
Old Sep 26, 2005 | 06:01 PM
i would say even ebay quality stuff prolly would last longer than that pacesetter
Old Sep 26, 2005 | 06:45 PM
honda_racing101's Avatar
Yep, a friend of mine had a pacesetter header and cat back on his civic, and both rusted/cracked within less than a year.
Old Sep 29, 2005 | 09:46 AM
s13_240sx_92's Avatar
Default Re: (honda_racing101)
Pacesetter is GARBAGE, fitment sucks, its loud and has angry bumble bee sounds. The one I had lasted for less than a year before there was a hole in the muffler. It rusted from the inside out, so even if you live in an area without road salt, its still not going to last that long.
I'd even go with a Tsudo SS exhaust for slightly more. The tsudo fitment sucks but its made of much better materials at least, and doesn't sound too bad. You can find these on ebay for around 225 shipped.
Of course if you can spring the extra 150 then get Apexi WS.
Old Sep 29, 2005 | 12:15 PM
integra15's Avatar
Default Re: (s13_240sx_92)
Ha I had a Pacesetter header on my old integra, I really can't say anything bad about it except that that black paint is gonna burn off within 5 minutes of using it and it will rust instantly.
Old Sep 29, 2005 | 02:55 PM
HxClude's Avatar
Default Re: (integra15)
Its the rust from the inside out that gets you.
S13 is right - go on Ebay and get either a Megan or a Tsudo. you can get one for the same amount of $$ as a Pacesetter, they sound ok, and they won't rust nearly as fast b/c they're stainless steel.
Old Sep 29, 2005 | 06:49 PM
Well it came in today, and it looks pretty good. I'm gonna drill a few very tiny holes in the bottom of each pipe to let moisture escape. It's a less common, but very big trick used by many companies. Back when the muffler was in the middle of the car, it kept warm enough to keep condensation out, but now that they're in the back, they rust out a lot faster. Many manufactures put very tiny (5-7mm) holes in the pipes and it usually helps a lot
Old Sep 29, 2005 | 09:11 PM
Default Re: (InvaderTrax)
When I had a Pacesetter on my Prelude the tips would rub against the rear bumper. Also you'll notice that the b pipe is too short. You'll have to put some tension on the exhaust mounts to connect the two parts of the b-pipe and clamp.
Let us know how it goes. I wonder if they made any adjustments.
Good Luck
Old Sep 30, 2005 | 12:47 PM
Well it's on. The tips are a little close, but there's still at least 3/8" between them and the bumper. No room for a rear lip though. The pipes fit together fine. Plenty of length. Only installation problem was the gasket was meant for a slightly different cat, so I had to adjust the screw holes a little. So far, power seems fine. My only complaints:
-Tips don't stick out much (1/4" on one, almost 0 on the other)
-Yellow painted inside the tips (gonna paint it black since it won't get dirty fast enough)
-Sound is more raspy then I was hoping for. It's got almost the same sound my ultra cheap, dual resonator system had (previous owner was really stupid and cheap, and now I'm paying for it)
On the plus:
-Power is good
-Just about exact fit
-Simple installation
EFlovin'
Oct 13, 2012 02:46 AM
on-the-line
19
Feb 21, 2007 03:45 AM
gator88
Jun 12, 2005 07:19 PM
meatball01
Nov 13, 2002 06:15 PM
